FP Green injector and fuel pump setup for 93 and E85
Old Dec 10, 2016, 03:03 PM
5k6
5k6's Avatar
What's the best injectors and fuel pump for a FP green on a stock block without running out of fuel and keeping the injectors at a reasonable IDC?
FP Green HTA MHI housing. GSC S2 cams. Evo 9. Want to run both 93 and E85.
I'm on a unmodified 255 fuel pump right now.
Old Dec 10, 2016, 05:28 PM
Bmurray's Avatar
I'm on a FP Red. Using 1200cc PTE injectors along with the AEM 320lph E85 pump with the STM rewire kit. Dual map tune. Made 475/408 on e85 and 441/382 on 93 with a lot of room to go.
Old Dec 10, 2016, 05:36 PM
5k6
5k6's Avatar
What's your IDC?
Just a normal rewire or with a Hobbs pressure switch? Does it overrun the FPR?
Old Dec 10, 2016, 07:35 PM
Bmurray's Avatar
Originally Posted by 5k6
What's your IDC?
~76% idc. Normal rewire
Old Dec 10, 2016, 07:46 PM
kaj
kaj's Avatar
1450cc injectors, Walbro 255. I run out of fuel pump at 450whp. 72.5% IDC.
Old Dec 19, 2016, 12:23 PM
bryan32123's Avatar
Originally had an aeromotive 340 and 1450CC injectors and were maxed out at around 500whp. I put in a Walbro 450 and made 603whp and then maxed out the injectors. I just put in FIC2150 and will be installing a double pumper and should be good to go. PTE 6262, built motor
Old Dec 20, 2016, 04:47 PM
5k6
5k6's Avatar
How do the FIC 1650s and 2150s idle on 93oct?
Old Dec 20, 2016, 05:13 PM
CDrinkH2O's Avatar
The High-Z version of FIC 1650 and 2150 idle well on 93 RON gas so long as you apply the injector linearization patch and settings detailed by mrfred in https://www.evolutionm.net/forums/ec...ion-table.html
CrazyLilPunk
Apr 24, 2016 04:17 PM
rickspecd
11
Sep 29, 2014 08:28 AM
rickspecd
EvoX 'For Sale' External Engine / Power
11
Sep 29, 2014 08:27 AM
Carloverx
14
Dec 22, 2011 01:00 PM
BigBallin
14
Mar 18, 2008 06:29 AM
Quick Reply: FP Green injector and fuel pump setup for 93 and E85
