how to change your rom or modify xml to show sas
Old Mar 18, 2015, 08:12 AM
garystanfield23's Avatar
how to change your rom or modify xml to show als sas
as above I've downloaded my rom evo 8 but it don't show als sas .. helllp
Old Mar 19, 2015, 02:16 PM
todd6027's Avatar
Originally Posted by garystanfield23
as above I've downloaded my rom evo 8 but it don't show sas .. helllp
whats the rom id
Old Mar 20, 2015, 12:27 AM
Originally Posted by todd6027
whats the rom id
93660005
Old Mar 20, 2015, 04:56 AM
todd6027's Avatar
add these to xml
<scaling name="IgnTimingECUa" units="deg" toexpr="61-x*90/256" frexpr="(61-x)*256/90" format="%.1f" min="-30" max="50" inc="1" storagetype="uint16" endian="big"/>
<table name="ALS minimum vehicle speed to trigger" category="Turbo" address="2212" type="1D" level="1" scaling="VehicleSpeed"/>
<table name="ALS minimum coolant temperature to trigger" category="Turbo" address="2214" type="1D" level="1" scaling="Temp"/>
<table name="ALS minimum RPM to trigger" category="Turbo" address="2216" type="1D" level="1" scaling="RPMStatLimit"/>
<table name="ALS minimum load to trigger" category="Turbo" address="2218" type="1D" level="1" scaling="Load16"/>
<table name="ALS minimum time to trigger" category="Turbo" address="221a" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS trigger valid time" category="Turbo" address="221c" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Load below which active" category="Turbo" address="221e" type="1D" level="1" scaling="Load16"/>
<table name="ALS active time limit" category="Turbo" address="2220" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Delay before air injection" category="Turbo" address="2222" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Delay before fuel injection" category="Turbo" address="2224" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Fuel injector time" category="Turbo" address="2226" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Air injection time" category="Turbo" address="4866" type="2D" level="1" scaling="Timesecbyte">
<table name="RPM" address="64c0" type="X Axis" elements="9" scaling="RPM"/>
</table>
<table name="Ignition Retard Limit" category="Timing" address="173e" type="1D" level="1" scaling="IgnTimingECUa"/>
Old Mar 20, 2015, 02:37 PM
thanks mate but I don't know where to put them lol can you help please i dont have xml lol
all i get is this type of stuff lol % #  Ç ÿ ÿ v È È ÿ ÿ P   · ÿ  < ( ( œ
  8 * F 8 0 @ f š M f Z *    ¡ @ @  t z ÿ P (°@ A¯ÈÖÐ  z Z Ø œ  = .  È   À @ €   €    š   Í m p    @ ÿ x  <     Z
(   0 š ä d m  g @ = h æ
 g ( @  u P ‘ à € ÿ ÿ ÿ    !  K   n  d     s € s
  ú   ( (
i guess i need the xnl for my rom id ?
Old Mar 23, 2015, 08:31 AM
todd6027's Avatar
look in my computer /C: /program files /open ecu/ ecuflash/rommetdata /mitsubishi /evo
then attach the xml here il add the info
Old Mar 25, 2015, 09:08 AM
Raptord's Avatar
Open the xml with notepad (notepad++ recommended instead for easier reading).
Old May 19, 2015, 08:34 AM
Umbravir's Avatar
Hi everyone.
How to add xml definitions for SAS for 88580714? Does it support it btw?
Old May 20, 2015, 05:44 AM
Rcus's Avatar
It should. /*Looks at 88580014 disassembly*/ Atleast code is still there @0x42330
Old May 20, 2015, 05:52 PM
Umbravir's Avatar
That is great! But what about XML definitions? Do you have any ideas about that?
Old May 21, 2015, 04:08 AM
Rcus's Avatar
Basic idea is simple. Get SH-2 disassembler and compare als code of ROM that already has als XML definition with yours. Or wait till someone who already did it will post definition here (might be someone already did it somewhere.)
Old May 21, 2015, 11:25 AM
Umbravir's Avatar
Basic idea is obvious, but I was hoping that someone already done this. Or that someone can do it much quicker than me. Because I've never disassembled our ROM. Maybe you can help me? I would be grateful.
Danny_lad
Oct 11, 2023 03:16 PM
BoostingHard
Dec 30, 2014 10:32 AM
batty200
Apr 11, 2013 01:56 PM
lancebin
Mar 7, 2010 06:45 PM
Quick Reply: how to change your rom or modify xml to show sas
