more boost control tables found
Old May 4, 2009, 09:13 PM
  #61
Jack_of_Trades's Avatar
Originally Posted by ExViTermini
Just added in the new tables for 0014/0015 and in the max upward, the right column wasn't visible and was nothing but about two dots. I have just installed the boost mods and haven't utilized them yet, but had to change the endian to big in the copied over values for my setup.
I had to go back and change the OffsetWGDC endian to little, while leaving the other 3 alone, in order for the right column to show up..
All endians either need to be big or little depending on your ECUFlash version. The address for the right column is wrong in the patch for the 94170015 rom. The correct address for the offsetWGDC is 4478.
Old May 4, 2009, 09:29 PM
  #62
shadow1's Avatar
For 94170014/15: the scaling is wrong. It should read:
<table name="Max Total Upward WGDC Correction vs TPS" category="Turbo" address="4478" type="2D" level="1" scaling="DynamicBoost">
<table name="TPS" address="69d8" type="Y Axis" elements="9" scaling="ThrottlePercentage"/>
</table>
Old Oct 23, 2009, 11:21 PM
  #63
ace33joe's Avatar
Did anyone find "min load for boost control" table for 941700xx maps?
Old Nov 16, 2009, 09:20 PM
  #64
Evo_Jay's Avatar
Im trying to add these tables to 96420011 but got a couple problems
On the "max total upward" I cant find the right address and/or scaling for TPS (left side).
Now on the max wgdc vs coolant temp, both sides are wrong.
here is the .xml data Im using.
Code:
		<table name="TPS" address="6b3a" type="Y Axis" elements="9" scaling="ThrottlePercentage"/>
	</table>
	<table name="Max WGDC vs Coolant Temp" category="Turbo" address="56d2" type="2D" level="1" scaling="WGDuty">
		<table name="Coolant Temp" address="5eae" type="Y Axis" elements="8" scaling="Temp"/>
	</table>
Old Nov 17, 2009, 04:15 AM
  #65
daymean's Avatar
Are any of these tables defined for 96260009?
Old Nov 17, 2009, 09:56 PM
  #66
Evo_Jay's Avatar
Code:
	</table>
	</table>
bump
Old Jan 5, 2010, 03:40 AM
  #67
Danieln's Avatar
Anyone has those tables for 88570007 or other JDM IX roms?
Thanks
Old Jan 5, 2010, 05:30 AM
  #68
Registered User
rolly1818's Avatar
Thanks
X2
i think we need to work together in getting 8857 in order.
Old Jan 5, 2010, 06:16 AM
  #69
Danieln's Avatar
Hi mate,
Definitely the info is somewhere......
Good to have a partner in this.....
Old Sep 16, 2010, 02:33 PM
  #70
VGergo's Avatar
Hello
so if my max total upward wgdc corr vs tps table set to 0 than my Boost error correction table can not work if the boost is lower as the desired ? For example If I set max upward at 100% tps to 5% , in the boost error corr table -2.4psi I have 6% and my boost error psi -2.4 than the ecu can raise the wgdc by 5% only ?
Old Sep 16, 2010, 02:57 PM
  #71
nonschlont's Avatar
Originally Posted by VGergo
Hello
if u set the "max total upward wgdc corr vs tps table" to 0, you wont get ANY positive correction! So if you set it to 5%, you will get up to 5% correction. Once u get the tune nailed down w/ out correction, I find 5% works well.
Old Sep 16, 2010, 03:11 PM
  #72
VGergo's Avatar
I think the same thank you
Old May 1, 2013, 08:39 PM
  #73
limaynard's Avatar
I have read through this and thought I had it nailed.
Set the BWGDC to what I thought was about right and added values in the Total Upward WGDC Correction vs. TPS but only over 62.4% TPS. I thought that this would mean no WGDC upward error correction until TPS was over 62%...
But I have found that WGDC is inline with the BWGDC table at high loads and increases in line with the Total Upward WGDC Correction vs. TPS but is way above WGDC at low loads.
I would expect that the WGDC would be the close to the BWGDC at low loads and below the TPS where upward correction should occur...
I will do some more logging and check but it looked odd...
mrfred
Dec 15, 2022 11:13 AM
mrfred
Aug 1, 2022 06:05 AM
itzwolf
Mar 15, 2022 06:18 AM
tephra
Aug 1, 2018 01:02 AM
Piper747
Oct 9, 2010 01:14 PM
Quick Reply: more boost control tables found
