Need AEm 3.5 bar Map sensor equation for Evoscan
Old May 5, 2011, 11:05 AM
Brad1907's Avatar
Hi everyone,
I'm looking for the equation so I can log boost with my aem 3.5 bar map sensor.
Old May 5, 2011, 11:19 AM
RoadSpike's Avatar
at least search it i don't want it dig it out of my notes everytime
I know i've posted it more than a few times already
Old May 5, 2011, 01:58 PM
Brad1907's Avatar
I used the equation you posted. (0.2451*x)-25.76. But this equation gives me -5.1 with the key on and the car off in evoscan. I adjusted it to (0.3051*x)-25.76, which gave me -0.1 psi with the key on and the car off. But this still seems to be readingnoff on from my boost gauge, it looks to be a couple of psi high.
Old May 5, 2011, 02:00 PM
RoadSpike's Avatar
Whats your altitude?
Use my 8 bit scaling table (second spread sheet) and see if you can't come up with some better values for the sensor.
https://www.evolutionm.net/forums/at...ling-chart.zip
Old May 5, 2011, 02:05 PM
Brad1907's Avatar
I'm at sea level like 200 ft. Or so. I'll check the scaling out.
Old May 5, 2011, 05:54 PM
Brad1907's Avatar
Well it looks like it is (0.2488*x)-20.848. This sensors range is only .5 volts to 4.5 volts.
Old May 5, 2011, 06:34 PM
RoadSpike's Avatar
Interesting I guess I probably fat fingered something when i got the equations ready the first time
Old May 9, 2011, 11:56 AM
VGergo's Avatar
Can I connect a Zeitronix ZT-2 3.5bar map sensor signal paralel with the Engine Ecu too ? The Zeitronix and the Ecu can share the same map sensor ? Or I must have 2 map sensor for the ZT2 and the Ecu too ? Thank you !
Old May 9, 2011, 12:27 PM
RoadSpike's Avatar
I suppose you could but that might degrade the signal a little bit.
The real question is why? It can be logged with evoscan no need to run it through the zeitronix unit again.
Old May 9, 2011, 01:39 PM
VGergo's Avatar
The customer want too see the boost after the tune without Evoscan on the ZT2 lcd. and ecu will control the boost with map and maybe speed density option in the future too.
Old May 9, 2011, 01:44 PM
RoadSpike's Avatar
Then just hook into the signal wire and its ground wire should be sufficient for a signal for both ecu and zeitronix.
Old Jul 28, 2011, 09:53 PM
CardShark's Avatar
What changes did you have to make to your ROM to run the AEM 3.5 Bar MAP?
I found these instructions for doing it with the JDM MAP and Omni 4-Bar but nothing on the AEM sensor:
JDM - https://www.evolutionm.net/forums/ec...tructions.html
Omni - https://www.evolutionm.net/forums/ec...evo-8-9-a.html
Old Feb 3, 2017, 11:17 AM
vanisher's Avatar
I know, slightly old thread but I'm looking to get an AEM boost gauge and want to log boost in evoscan. Any answer to this question?
Evo8life
Dec 2, 2017 06:05 AM
talonkev
Sep 21, 2017 04:54 PM
strykr
Aug 20, 2017 02:38 AM
Igor_Predator
May 7, 2017 01:13 AM
boosted91t
Apr 15, 2016 07:48 AM
Quick Reply: Need AEm 3.5 bar Map sensor equation for Evoscan
