Clutch switch LC vs NLTS
Old Aug 28, 2016, 11:37 PM
foxbat's Avatar
Got a JDM Evo9 RS, I previously tuned it using a V7 (88580714) but I never got launch control to work. The car seems to have an oem clutch switch but disconnected. I will connect the switch the pin # 88 & hopefully LC would work. This oem switch is the type that only works if the clutch pedal is fully depressed so I wonder if it would work for NLTS as well? Should I install a different type switch, a one that work when the pedal is slightly depressed?
Old Aug 30, 2016, 03:59 AM
tephra's Avatar
from memory some evo9's have two clutch switches,
one @ top of pedal that is normally pushed, and one at bottom of pedal
i was pretty sure the bottom one was used to stop people from starting the car without having foot on clutch...
check the top one?
foxbat (Aug 30, 2016)
Old Aug 30, 2016, 08:13 AM
foxbat's Avatar
check the top one?
An answer from the great Tephra! I wish I had asked a more important question
Yes the one I have is the bottom one, I think I'm going to install a different switch on top, but would one switch activate both LC & NLTS? What's the correct ECU pin#?
Old Aug 30, 2016, 04:24 PM
tephra's Avatar
haha
well im pretty sure the AUDM 9's didn't have a bottom clutch switch, at least we didn't need to push the clutch in to let the motor crank.
so i assume that the top clutch switch does stationary rev limitter, which i guess you call LC
no idea on pin im afraid, but if your lucky you should have a plug up under the dash just waiting to be connected
Old Aug 30, 2016, 04:46 PM
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
I thought the top clutch switch was only for NLTS, and launch maps were enabled by being below a certain speed...? I actually remember testing the launch maps in my car by just sitting still, just using the brakes to hold the car still. I was always able to test my launch maps as long as the car was sitting still. No need to depress the clutch.
Old Aug 30, 2016, 09:20 PM
Macaroni's Avatar
Mine is the same way. Clutch switch is only to activate NLTS. Launch maps work off vehicle speed.
Old Sep 5, 2016, 05:15 AM
todd6027's Avatar
Correct , top switch is for nlts
Old Apr 4, 2022, 10:09 PM
aqeelrizni's Avatar
Only pin 88 in 3 plug ecu?
My JDM 8 gsr did not come with a top clutch switch. Wired it into pin 88 in the 3 plug ecu. Doesnt seem to enable NLTS even though I have enabled it in the rom. Any other way to test if the clutch switch is working?
Old Apr 5, 2022, 09:38 AM
audiofan's Avatar
Try a V5 Tephra rom, on my car NLTS did not work with V7, tried V5 and it works
Old Apr 9, 2022, 05:25 PM
aqeelrizni's Avatar
I'll try a v5. But Hyperdisorder had managed to successfully get it running on the 9627 v7 rom. I'll try hitting him up
Old May 2, 2022, 09:24 AM
Wulfen's Avatar
NLTS worked on my evo 8 and two other 8s in my area. All 3 are JDM on the 9653 v7 rom.
Old May 16, 2022, 02:04 AM
I<3myevo6's Avatar
Guys, I am running a Evo 5 with a Evo 7 ECU via a Tephra V7 (90550001), Kindly help me on the below 2 issues:
-> NLTS is not working
- If turned "on" I am hitting a weird rpm cut at 5-6K RPM, car work fine if NLTS is turned off
- Have wired the grounded clutch switch wire to pin 43 of the ECU
-> Valet does not work on fresh ignition
- If valet function is turned on for fresh ignition the car is always on the set rpm limit(valet) unable to get out
- Valet function work fine if refers on fresh ignition is not tuned on
Pls feel free to ping me at sharewithraj at hotmail.com
Old May 16, 2022, 02:21 AM
Wulfen's Avatar
I've had a client Evo 4 with Evo 7 ECU. It had the same rom as you but it was very buggy so I switched him over to 96530706 v7. It's been working well ever since so you can try that.
I<3myevo6 (May 16, 2022)
Old May 16, 2022, 02:48 AM
I<3myevo6's Avatar
Thanks for the Response, When you get time can you pls share the files to my email? sharewithraj at hotmail dot com
Old May 16, 2022, 02:51 AM
Wulfen's Avatar
Sure
Teufel
Nov 28, 2015 04:05 PM
TJung
Sep 8, 2015 09:57 PM
Ilwrx
Mar 27, 2009 09:10 AM
evane
Jan 12, 2009 12:36 PM
evane
Jan 9, 2009 10:06 AM
Quick Reply: Clutch switch LC vs NLTS
