BBK full vs Tomei ARMS vs Old Green vs ATP Gold
Different days, same dyno settings
All cars very similar supporting mod wise. Yes, our dyno figures are pretty low in Australia compared to you guys in the US
Blue - 8MR BBK full, 260 Tomei pon cams, Tomei cam gears, Full-race pro stock manifold, single Walbro pump, HKS intake, Tomei 02 & down pipe, resonated test pipe, Garage HRS Ti cat back, FIC 1050cc injectors, bar&plate 600mm intercooler, 2.5" I/C pipes, Tomei FPV, ECU flash
Red - 8MR Tomei ARMS, same car different turbo
Green - 9 Old Green, rebuilt engine with standard parts, 260 Tomei pon cams, Tomei cam gears, Tomei 02 & down pipe, custom 3" cat back, 100 cell cat, single Walbro pump, APS(?) CAI, HKS type-R intercooler kit, 650cc injectors, Motec M800
Pink - 8MR with ATP gold, 260 Tomei pon cams, Tomei cam gears, Tomei 02 & down pipe, test pipe, 3" cat back, single Walbro pump, GruppeM intake, Greddy type-S intercooler kit, 750cc injectors, Motec M800
im finding it odd that the gold is out doing the BBK. Out the info i could find online about the gold i would have assumed it would not flow as much as a BBK full beings the gold is only a comp wheel upgrage with a new compressor housing.
Well, I'm the one with the BBK. Adjusted cam gears for ultimate response, not many evo 8s with 20Gs or above can hit full boost at 3500rpm. Compensated top end for response.
Apologies for the lack of information. Just thought I'd post some comparisons me and my mate's cars on a very similar playing field.
More details added
I think my tuner advanced the inlet cam by 15 degrees? I might be wrong
Well I guess I classify anything around that flow range as a 20G, bad definition.
Only the car with the ATP gold is running higher boost levels then the rest. Owner just wanted big numbers.
You're probably thinking of another ATP gold? This one is specially made by ATP Turbos in Melbourne. Upgraded comp housing and wheel.
http://www.atpturbo.com.au/ATP_Turbo...LD-Wheels.html
More details added
idle
Mar 22, 2012 02:48 AM
EVOVII_SWE
Aug 23, 2004 03:11 PM
