Heavy Modifications on my Evo 7
Old Dec 22, 2005 | 10:26 PM
rgowani's Avatar
Hi guys,
this is my first post here. I am Rishabh from Mumbai, India. I finally went and bought myself an Evo 7 after waiting for 3 long years for the opportunity. It was tuned in Dubai and is on its way to Mumbai now. Well I would like to know if this setup is alright and to increase Torque what else should I do?
  1. Arias Forged Turbo Pistons
  2. Tomei Forged Connecting Rods
  3. ARP Head Bolts
  4. Tomei Metal Head Gasket
  5. Tomei Titanium Retainers
  6. Tomei Valves & Valve Springs
  7. Tomei Adjustable Cam Gears
  8. Greddy T67 Turbo
  9. Greddy Stainless Steel Manifold
  10. Greddy Adjustable Wastegate
  11. Greddy Blow-Off Valve
  12. 255 Litre/Hr Fuel Pump
  13. SARD High Flow Fuel Rail
  14. Power Enterprise 1000cc Injectors
  15. CPR Fuel Pressure Regulator
  16. Greddy Oil Catch Tank
  17. Trust Type R Adjustable Wastegate
  18. Greddy Downpipe
  19. Greddy 3" Titanium Exhaust System
  20. Airnix Foam Filter Intake
  21. Blitz Aluminium Radiator & Silicone Hoses
  22. Trust Intercooler Kit
  23. OS Giken Double Plate Clutch
  24. TEIN Adjustable Coilovers
  25. HKS Turbo Timer
  26. Defi Link Gauges
  27. Motec M800 ECU
I had also fitted Tomei 280° Camshafts but due to some problem according to the tuner he had to remove them and put the Original Cams. After all of these modifications my Dyno result was 441.1 HP @ 6737 RPM & 381.8 Lb- Ft @ 5352 RPM with 95 Octane Fuel. I am going to drive this car like a maniac always in the 8000 RPM Range. I have kept the RPM Limiter to 10000 RPM. Now I would like to know whether its safe to keep 10000 RPM as my limit with these modifications or should I keep it less. This car is going to be used for Drag as well as Circuit Racing as well as a Daily Driver in Heavy Traffic. Is there any way I can increase my Torque and also I have installed Anti-Lag by Motec. Is there any other modifications I should go for? Also is there any Semi Automatic Transmission availiable for the Evo 7 ???
Thanking you,
Rishabh
Old Dec 22, 2005 | 10:35 PM
rgowani's Avatar
Also I forgot to mention I am runnig boost at 2.2 Bars.
Old Dec 22, 2005 | 10:39 PM
Ultimate CC's Avatar
Sounds like a beast, get some pics asap, as far as torque goes a stroker kit would be night and day difference
Old Dec 22, 2005 | 10:40 PM
CRVdrftR05's Avatar
lol Yay another CRV driver! ;p
Old Dec 22, 2005 | 10:59 PM
rgowani's Avatar
Well thanks alot. The car is on its way to Mumbai and then it will take a week to clear it in the Customs so hopefully by 1st week of Jan I should have the car. Will definately post pics soon.
Old Dec 22, 2005 | 11:00 PM
rgowani's Avatar
Is there any other better Air Filter? I did not like the Airnix.
Old Dec 22, 2005 | 11:02 PM
WHTEVO's Avatar
i would say go with an hks or buschur intake.
a stroker would definetely give you the torque you are looking for.
good luck and get pics up of your car when you can, it sounds nice.
Old Dec 22, 2005 | 11:04 PM
rgowani's Avatar
Also can I use 100% Methanol in this setup?? Or I have to carry out some modifications for that as well.
Old Dec 22, 2005 | 11:06 PM
Soon2BEVO's Avatar
Its not going to last going to 10,000 RPM playa
Old Dec 22, 2005 | 11:10 PM
rgowani's Avatar
So then I should use it 9000 or 8000 RPM ???
Old Dec 22, 2005 | 11:16 PM
Soon2BEVO's Avatar
Well you have a built head which is good and it can handle some high revs... (9300 or so), but if you want it to last, I wouldnt reccomend playing that high unless necessary, its just a lot of stress.
Old Dec 22, 2005 | 11:20 PM
rgowani's Avatar
I am thinking of having another Engine built. Which tuning company in Japan would you'll recomend for gettin the engine made. Money no object job.
Old Dec 23, 2005 | 12:20 AM
Soon2BEVO's Avatar
Well my personal preference of engine building would be Buschur who is here in the US. He did Shepherd's motor which has well over 1000HP.... hows 56psi+nitrous sound!!!
Old Dec 23, 2005 | 12:47 AM
GTREVO's Avatar
10,000 rpm at 2.2 bar seems like a perfect recipe for disaster on 95 octane fuel. The Greddy T67 does not like big boost especially on a standard thrust bearing it has if not upgraded. Run a Tomei 2.2 or a Magnus/Buschur 2.3 stroker bottom end to get that torque. You can retro fit the automatic transmission from the Evo 7.5 GT-A which also works as a semi auto but its a lot of work to do.
For a big chunk of money you can get Tomei to supply you a completely built engine to your specifications. PM me if you need help to get that. THey can supply you the 2.2 stroker engine with your choice of camshafts.
Old Dec 23, 2005 | 12:59 AM
rgowani's Avatar
I would like to understand how do High Lift Cams actually help? I want only low down grunt and not lookin at top speed.
