Pistons rings clearance
Old Oct 16, 2008, 11:41 PM
konstantinosIX's Avatar
My car is my DD.I also use it for street races... once maybe twice a week and the pump boost is 26psi for DD to 35 psi for street races.
Old Oct 19, 2008, 12:11 AM
Monday we will install the pistons and rings.
Does any evo builder can help us with the decision of the top rings end gap?
Old Oct 19, 2008, 08:31 AM
03whitegsr's Avatar
Originally Posted by konstantinosIX
Cosworth Information and reference said the opposite.
Top Piston Ring gap 0.40-0.46
Sec Piston Ring gap 0.36-0.41
Oil Piston Ring gap 0.20-0.70
I'd call Cosworth and double check that, because that's the first time I have ever seen a smaller gap on the second ring being recommended.
Bad things like....
Serious scaring of the cylinder walls if you're lucky, broken ringlands or possibly a seized piston/ring leading to complete motor failure.
Old Oct 19, 2008, 08:56 AM
I has a pdf file with all these specs from cosworth.
I am wondering... how much oil a built motor is burning?
Old Oct 19, 2008, 01:53 PM
DimitrisIX's Avatar
I installed a JAM stage 2 shortblock recently. I broke it in for 500 miles on mineral oil and no boost. After that semi synth oil and 0.5 bar max because I am not tuned for my cyl. head and cams. It does not use any oil so far but I am not pushing it. I would say the engine feels smoother than my stock engine even though it has forged internals that are supposed to make more noise on startup etc.
Old Oct 26, 2008, 06:09 PM
EvoM Moderator
joedr's Avatar
FYI!
Be adviced that there are two different common alloys on forged pistons. 4032 and 2618. Both with different expansion rates under temp. Consult your pinston manufacturer or experienced builder for the suggested clearance based on the application that you are going to have.
Wiseco used 2618 and mine were installed 0.022 top and 0.020 second ring. No issues so far @ 24-26 PSI.
tscompusa
158
Jan 17, 2017 02:52 PM
cerevo
12
Sep 9, 2016 03:45 AM
kylefowlie
Dec 21, 2015 11:54 AM
Matthew333
Oct 26, 2010 02:44 AM
stealth-wrx
10
Jul 2, 2006 08:47 PM
Quick Reply: Pistons rings clearance
