Speedomter/Odometer not working
Old Dec 13, 2011, 03:45 PM
shrtstuff89's Avatar
Speedometer quit working, sitting at zero mph. Along with it, the odometer isnt going up. Weve changed sensors, changed clusters, and still nothing. Abs still works, resetting the relay didnt do anything. Im trying to figure out anything else before i start chasing wires thru the engine bay. Sadly if i cant get it working, itll go to the stealership.
Old Dec 13, 2011, 03:48 PM
bigben's Avatar
Does the car start at all? Is the 40amp fuse underneath the hood blown? I popped mine today and it won't power up the gauges at all.
Old Dec 13, 2011, 04:32 PM
Car starts, runs, drives fine. But no odometer reading or speedometer. The fuse was fine. Under the hood and under the coinbox
Forgot to add, the fuel gauge, temp gauge, and tachometer all work. Have to use a gps right now to know my speed
Old Dec 14, 2011, 06:34 AM
If I can figure out where to try and run it from/to ill take and try to run a new wire from the sensor to the cluster or whatever. What do Ye gurus think
Old Dec 14, 2011, 06:44 AM
WHTEVO's Avatar
Have you tried pulling the cluster out and seeing if anything is fried on it? Sometimes reseating it may help.
Aaron
strykr
Nov 18, 2016 07:32 AM
MisUnderStood
Sep 27, 2015 07:21 AM
jsdragonsoul333
Lancer Troubleshooting
Feb 5, 2011 10:16 PM
tmt502
Dec 27, 2007 06:07 PM
Pesto360
Sep 12, 2004 03:18 PM
Quick Reply: Speedomter/Odometer not working
