Converting Evo trans back from Push Style
Old Dec 2, 2014, 09:00 AM
evotuner04's Avatar
Do any of you guys have the part numbers needed for converting the clutch back to pull type from push?
I couldnt find a transmission schematic anywhere on google, any help is appreciated. Thanks
Old Dec 2, 2014, 10:48 AM
94AWDcoupe's Avatar
some conversions did not need to change the factory parts out. so they are easily reversed. which push clutch are you removing?
Old Dec 2, 2014, 10:52 AM
evotuner04's Avatar
It was a quarter master
Old Dec 2, 2014, 03:40 PM
mrflipflops's Avatar
I am about ready to do the same thing and could use this info as well.
Old Dec 2, 2014, 03:42 PM
mileb's Avatar
What clutches do you guys have and why? I assumed push style was the way to go. I;m just curious as im clutch shopping as well.
Old Dec 3, 2014, 10:19 AM
thepoint4life23's Avatar
Yea i would like to know why your changing back.
Old Dec 3, 2014, 10:24 AM
I think this may help just do it the other way around http://competitionclutch.com/tech/PUB-45106-1.pdf
Old Dec 3, 2014, 01:48 PM
evotuner04's Avatar
Never heard the greatest of things about them and this car was aleady in pieces when I got it so I'm going back to what works best and is simple to me.
Old Dec 3, 2014, 02:22 PM
Cadmonkey's Avatar
i have a comp twin so its a bit different for me, but ill try
i know with my set up, the slave cylinder is reversed. so, that would have to be put back to its stock configuration. i think the QM's use a hydraulic TOB instead of a slave cylinder? so maybe even a new TOB
the clutch fork has two little springs that are needed in a pull configuration that arent used on a push style clutch. i called stm and they have all the little parts that go on the clutch fork. pilot pin, felt washers, springs
on my clutch, there is no need for a wave lock retaining clip. you will need this for a pull style. id suggest an ACT monolock, as it is one piece and less likely to pop out on you. or maybe even a clutch fork stop.
im not at all an expert on these things, but maybe this will help
Old Dec 3, 2014, 05:14 PM
evotuner04's Avatar
Thank you sir. My tuner gave me a pretty extensive list. I just wanted part numbers but a member here has taken care of me so hopefully that'll be all I need.
mchristian
63
Jun 19, 2014 04:49 AM
rgar
Apr 24, 2010 01:03 AM
awdwannabe
Jan 13, 2009 10:25 PM
evodrivesme
12
Aug 20, 2006 09:16 AM
Quick Reply: Converting Evo trans back from Push Style
