weisco piston ring correct orientation!
i wanted to know, does the oil expander ring gap come 90* degrees from the wrist pin or it comes on top of the wrist pin?
plus do the compression rings gap come on top of the wrist pin, 180* degrees to each other?
meaning the top compression ring gap is on one side of the piston and the second ring gap is opposite it..
i think my mechanic, installed the rings all wrong thats why the car is giving blue smoke, now i have to tell him the correct orientation, need all of the help i can get!
https://mikesbasketcase.wordpress.co...wiseco-piston/
The pink sheet at the bottom. Did this a couple days ago. They also usually send a card in each ring pack.
hi all i am new to the forum, the guidance of her gap ring piston not think it has much importance because when the engine is running rings move and are turning and the piston, the placement of the upper ring correctly if is very important for proper selledo and scrape the oil from the cylinder walls
silverofs
Jan 12, 2014 06:31 AM
ezzey
Dec 6, 2012 09:58 PM
