Rotating Assembly Refresh with Pics
This motor was originally assembled for me by Jackson Auto Machine (Hanover, MD) back in 2006. After getting away with quite a lot (550-600whp on 93 octane) for a good part of that time, leakdown issues in #s 1 and 2 necessitated a refresh. The risk of running things on the edge is virtually zero margin for error if some part of the system misbehaves, and this motor has weathered a fair amount of peripheral misbehavior over the years without losing its cool. Jerry at Jackson had the original notes on this one, so he was a big help in getting replacement parts sized correctly.
The crank and rod journals remained like new, without wear or blemishes.
The rod bearings were in relatively good condition, with the original dry film coating present.
The bores were sharp and without measurable wear, requiring only a 320 grit deglaze and thorough cleaning.
The rings and ringlands of pistons 1 and 2 had taken a beating however, from either detonation and/or misfire, so it was time for a refresh.
New custom Venolia pistons, calculated at 9.0 SCR with my particular head and setup, notched for squirters and thermally coated, 352g.
King bearings, Calico dry film coating.
Oliver CNC lightweight billet rod, 156mm, 586g with fasteners. No Chinese metallurgy here. You can will these to your grandchildren.
Assembled piston.
Closeup of CNC machined Teflon button. These can be reused again and again.
Closeup of Total Seal gapless moly 1st ring with grooved rail. This ring set requires different gap settings than standard rings.
Composite:
Assembled piston.
Composite:
Those pistons look nice. Are they billet or forged?
This piston is designed to withstand extreme thermal abuse without skirt issues, given pump fuel, high boost, and shorter compression height. The condition of the last set convinced me to stick with them. IIRC, the pin walls are 0.200".
The rods are simply what Oliver delivers for the money. I wasn't on a weight saving mission when I bought them.
norcalSRTrida
16
Jan 2, 2009 10:37 AM
Evo_SpeedKing
92
May 28, 2008 08:48 AM
RalliartMR
Jan 14, 2008 07:57 AM
Evo_SpeedKing
57
Nov 19, 2007 09:35 PM
hotrod2448
21
Nov 15, 2006 07:17 AM
