Spun bearing?
Old Apr 19, 2015, 08:58 PM
the_evodude's Avatar
Delete
thanks guys
Old Apr 20, 2015, 10:31 AM
thepoint4life23's Avatar
Sounds like lifter tick. but there is a odd of beat sound. I would change the oil and look for flakes in the oil
Old Apr 20, 2015, 07:34 PM
Evo-IXse06's Avatar
Might be a really bad lifter thats stuck take em out and bleed em
Old Apr 21, 2015, 02:03 AM
Ausevo7's Avatar
I'd say lifters.. that off beat sound, sounds as if the rocker is moving about. Pull the valve cover and see whats going on in there. If that rocker falls out its place it could get a bit nastier than just lifters.
Old Apr 21, 2015, 01:53 PM
sujinX's Avatar
lifter tick. theres a correct way to bleed the lifters and a wrong way.
Old Apr 21, 2015, 07:53 PM
Ausevo7's Avatar
I thought this as well, but i've seen numerous different ways to bleed these lifters and they all pretty much give the same result.
- bleed lifter in diesel oil ( how I bleed them )
- bleed lifter in oil
- bleed lifter with no fluid until lifter is empty ( this one takes the longest for lifter tick to go away due to no oil inside until oil pressure has filled it )
Workshop manual uses diesel oil method.
nateevo8
Sep 7, 2013 08:46 AM
expl0d
Sep 17, 2007 11:33 AM
RayBaer
228
Mar 28, 2006 04:13 PM
Torre from Va.
Dec 21, 2005 06:09 AM
BoostnEvoNaz
Mar 7, 2004 07:23 PM
Quick Reply: Spun bearing?
