Basic bolt-ons, pump gas, Ported CBRD BBX turbo, MAP o2 elim, DB Performance tuning
Got the new setup tuned today! As usual, Shane couldn't push timing much as beaterX is kinda a ***** and/or we just don't have very awesome pump gas around here. Shane said that the car *loved* timing in that it would make decent gains for every degree added but it wasn't always liking it. We ended up running only about 13° up top, really a lot less than I expected, but the car feels fantastic now.
It rolled in at 321whp @27psi tapering to 25-25.5 and left with 346 @ 28 tapering to 26 and a crap-load more midrange than it came in with. More on that in a sec.
aFe Stage2 intake
stock maf housing (touching 4.9v@7500rpm, oopsie!)
Perrin intake tube
Excessive Autosport 2.5" UICP
Excessive Autosport PTE 3" x 18" x 12" FMIC (not much bigger than stock)
CBRD BBX turbo (ported by CBRD, ceramic coated hotside by MAP)
MAP o2 Elim downpipe (recirculated)
Megan Test Pipe
Magnaflow Catback
DW 800cc injectors
Hallman MBC
stock longblock
stock manifolds
stock everything else
Dyno Dynamics numbers, 1.0CF:
Shootout/Dynojet numbers:
28psi peak, tapering to 26. Here's where a BCS might help a bit up top, but my FMIC is overtaxed as it is, so meh. Both Bryan@GST Motorsports and Chad@CBRD said that every psi over 25 yields great great gains on this turbo and that 28 is a great target for pump gas.
Nice and rich to help prevent knock
Here's the best! When I first bolted this thing on, it was at or below the torque of my stock turbo. NOW with the tuning love from DB Performance, I went from 282wtq on the stock turbo to 311wtq with the BBX! Granted, I also have the MAP o2 elim downpipe on the car now as well but it really doesn't matter, the new setup lost some spool but I'm up torque and power bigtime!
+68whp/+29wtq over the stock turbo
Lost about 800rpm of spool, but this turbo is rated at 58lbs/min. Seeing 25psi by 3900rpm is pretty damn good imho.
I'm extremely happy with the new setup! So smooth, decent power, and should be very reliable. Time to go to the track and see if I can get this bish into the 12's! I've got 2000 miles on the ACT 6-puck and 1000 miles on the BBX already; I'm ready to just keep driving this thing and keep having fun!
More info on my 'beater' here:
https://www.evolutionm.net/forums/ev...-ton-pics.html
https://www.evolutionm.net/forums/ev...time-blue.html
aFe Stage2 intake
Perrin intake tube
Megan Test Pipe
Magnaflow Catback
DW 800cc injectors
Hallman MBC
stock longblock
stock manifolds
That thing owns the stock turbo, nice. I have a question about the 28 to 25 taper is that because of pump gas or because of something else, could you run 28 across the board?
scheides
Evo X Dyno Results
27
Feb 22, 2011 06:59 AM
scheides
Feb 13, 2011 03:44 PM
scheides
Aug 23, 2010 08:59 AM
