codes
Old Feb 9, 2015, 03:30 PM
elkazX's Avatar
codes
So i plugged in my accessport today just to read some codes and i got the codes p0219(engine overspeed) c1219, and u0428. How do i clear the engine overspeed and why would i even get that code? Is it due to a misshift? I do not remember misshifting as i rarely even go full throttle. And what would the other codes be associated with? I have the 4wd service light on and the traction control service light on whatever that is abbreviated with i cannot remember at the moment. Also it does not let me switch between tarmac, gravel and snow which is most likely related to one of these problems. Thanks in advance!
Old Feb 10, 2015, 07:09 AM
hoobastnk90's Avatar
Well sounds like you mis shifted it or somebody did.. So what happend usually codes just dont pop up for no reason?
Old Feb 10, 2015, 09:25 AM
elkazX's Avatar
Obviously..I know this. I said I don't recall but it is a possibility, as that is not the issue i am trying to figure out/resolve.
Old Feb 10, 2015, 11:41 AM
How do you not remember over reving the car? Its usually a pretty violent event like its not something you can do and not realize..
Old Feb 10, 2015, 02:23 PM
elkazX's Avatar
it couldve been months ago for all i know. All i said was i do not remember recently doing that, now once again, that is not the problem that is trying to be resolved here.
Old Feb 10, 2015, 02:31 PM
Well from the quick search i did it sounds like a steering angle sensor issue. Most people said you can kind of reset it by jiggling the sensor that is located behind the steering wheel. Or just take it to the dealer and have them replace that sensor under warranty.
https://www.evolutionm.net/forums/ev...428-c2205.html
Old Feb 10, 2015, 03:27 PM
elkazX's Avatar
not sure if warranty would cover it..as i am modded and also my 3 year warranty just ran out. so jiggling the sensor you mean take the steering wheel off?
Old Feb 11, 2015, 06:48 AM
Yea it does seem to be located behind the steering wheel but it looks like there is a way to get to it by just removing the plastic cover on the steering column.
http://www.evoxforums.com/forums/sho...d.php?t=256153
Not the same problem as your but at least you can get an idea of where it is located.
Old Feb 11, 2015, 02:14 PM
elkazX's Avatar
ill try that then reset the codes and see what that does. thanks
HiRevnVIII
Mar 1, 2010 05:58 AM
Evo8Emperor
Mar 13, 2008 01:00 AM
expl0d
Jul 17, 2005 05:12 PM
Quick Reply: codes
