Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Invidia downpipe Install evo X FML!
Old Apr 19, 2012, 08:42 PM
dsmturbo87's Avatar
Angry Invidia downpipe Install evo X FML!
Is there any tricks to installing an invidia downpipe? I can not see any way to access the bolts in a way to get any leverage . I used ever tool in the book i removed the heat sheild and strut bar and also tried reaching up from underneath still had no room to get any kind of wrench on the bolts.. PLEASE HELP
Old Apr 19, 2012, 08:58 PM
momostallion's Avatar
extensions and wobble sockets?
Old Apr 19, 2012, 09:08 PM
dsmturbo87's Avatar
i almost need two wobble sockets and two long extensions..any other tips
Old Apr 20, 2012, 07:30 AM
ProjectGSX's Avatar
There are a couple of other downpipe threads in the how-to section with lots of info. You should be looking there for info.
Old Apr 20, 2012, 12:18 PM
Jossue's Avatar
You could remove the exhaust manifold and turbo with the downpipe as a whole........
Old Apr 20, 2012, 12:22 PM
SilverShadow03's Avatar
Here you go:
https://www.evolutionm.net/forums/ev...tructions.html
https://www.evolutionm.net/forums/ev...tallation.html
http://api.viglink.com/api/click?for...13349497080161
Old Apr 20, 2012, 12:35 PM
dsmturbo87's Avatar
Ok thats a good how to but i was installing an Invidia dp which retains stock (o2 housing) I basically couldnt break the spring bolts loose i had to use an extension.
AND this will be a helpful tool as well
Old Apr 20, 2012, 12:36 PM
So....are you saying you got it? I've reread your last post a couple of times....still scratching my head.
Old Apr 20, 2012, 01:19 PM
dsmturbo87's Avatar
Yeah im sorry i did get it I posted a pic of the tools i used so maybe it will help someone else out..
Old Jan 31, 2014, 02:55 PM
tybojengles's Avatar
How the hell did you get the rear lower bolt that's on the other side? I can't get it for the life of me!
Old Feb 1, 2014, 12:39 PM
ikt
ikt's Avatar
under the car, using a long extension and a wobble head with a torque gun, access it along the down pipe area
wiseguy9
Nov 24, 2014 09:16 PM
master c
Oct 20, 2013 04:06 PM
mrm95
Jul 3, 2013 10:24 PM
PICASO83
Oct 17, 2012 05:01 PM
MRevolicious
Apr 28, 2011 02:34 PM
Quick Reply: Invidia downpipe Install evo X FML!
