Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
How is the rear camber adjusted?
Old Oct 3, 2009, 07:58 PM
dragon831's Avatar
What exactly is modified in order to change the camber in the rear?
Old Oct 3, 2009, 08:31 PM
goofygrin's Avatar
There are two eccentric bolts/washers in the rear on each side. One changes toe, one changes camber.
You need two 17mm wrenches. You loosen the nut on one side of the $20 bolt and then turn the bolt head to roll the $10 washer in a slot cut into the suspension arm. Once it's set, then you tighten the nut back down. These bolts/washers last approximately 6-7 alignments before one or the other strips out. In my case it's been the washer. This is especially true if you are aggressively dropped and you're putting a lot of pressure on these pieces to get a good alignment.
Of course if you take it to a place and they can't figure this out by looking at the rear suspension for about 2 seconds, then you need to take the car somewhere else.
Old Oct 3, 2009, 08:56 PM
DannyK24's Avatar
lol @ pointing out prices. I had no idea the Evo didn't need a rear camber kit until I ordered the BC coilovers. Easiest suspension install ever.
QCRVR
Outlander Sport
Oct 4, 2016 02:29 PM
dipsetinallday
11
Apr 28, 2016 06:02 AM
mitsuevodriver
19
Jan 17, 2016 08:37 AM
TEXAS TRAVISTY
Outlander Sport
Aug 24, 2015 05:39 AM
AhmadHasib
Jun 12, 2006 11:00 PM
Quick Reply: How is the rear camber adjusted?
