Dumb parking question
Old Jul 11, 2009, 09:45 PM
AM-EVO's Avatar
Hi all,
I get that it's recommended to keep the car in gear when you park (1st if uphill and reverse gear if downhill). But my question is, does it matter in what order?
What I mean is, is it better to:
METHOD A:
1. Stop the car
2. Apply the parking brake
3. Shift into 1st or Reverse gear (While car is still running)
4. Turn off the ignition
OR
METHOD B:
1. Stop the car
3. Turn off ignition
4. THEN shift into 1st or Reverse gear (after engine is off)
I've been following method A for years now. But after reading the users manual that came with my Evo X, I'm not quite sure if either method is better or worse for you car, transmission, etc. Any thoughts?
Old Jul 11, 2009, 10:00 PM
IllusionAstarz's Avatar
I usually pull up the parking brake,turn the car off then put it on gear.hope that helps.
Old Jul 11, 2009, 10:07 PM
Lancerguy'03's Avatar
i dont think it makes a bit of difference....stop being so ****.
Old Jul 11, 2009, 10:09 PM
ablan029's Avatar
is this really a thread??
Old Jul 12, 2009, 06:59 AM
Raptord's Avatar
As long as you're not making the engine stop running by purposefully stalling it, either method should be fine
I follow method B myself.
Old Jul 12, 2009, 08:07 AM
EvoM Administrator
otter's Avatar
Originally Posted by AM-EVO
Hi all,
METHOD A:
1. Stop the car
OR
METHOD B:
1. Stop the car
It doesn't matter.
Old Jul 12, 2009, 08:45 AM
AM-EVO's Avatar
Thanks for the input everyone.
Yeah, it's a dumb question. I just wanted to make sure I wasn't causing any minor damage. One of my friends mentioned something about it not being good for the transmission if you shift gears while the engine is off....that's why I figured I'd ask.
Old Jul 12, 2009, 08:59 PM
no your fine either way
/thread.
Old Jul 12, 2009, 10:12 PM
ODUB's Avatar
i don't ever put it in gear when i park. i just use the parking brake. i don't ever park on hills either though. louisiana is pretty flat
Old Jul 13, 2009, 05:58 PM
supasixfo's Avatar
yeah, just make sure you put the clutch in before you shift, after you turn the engine off. also make sure you apply the parking brake proportional to releasing the actual brake, and at the intersection of braking friction versus horizontal momentum.
Old Jul 13, 2009, 06:20 PM
icole's Avatar
I do not even use the parking break, and I put it in first before I turn of the engine regardless of the direction of the hill.
Old Jul 13, 2009, 08:20 PM
tristat3's Avatar
i have remote start on my evo i just put the e brake on
Old Jul 16, 2009, 04:13 AM
2plaz's Avatar
i use chocks
someone please close this thread... seriously.
crypto
Lancer How Tos / Installations
22
Feb 1, 2017 11:39 AM
mrmiller
Jun 21, 2016 07:08 PM
jbrennen
May 14, 2016 10:04 PM
deegaw11
12
Mar 19, 2011 01:50 PM
TrojanMan
Apr 6, 2005 09:52 AM
Quick Reply: Dumb parking question
