Crank Pulley Noise
Old Jan 24, 2009, 08:25 PM
Dwalk08's Avatar
Crank Pulley Noise
I installed the RRM UD Pulley on my 06 Lancer ES and now there is a wierd noise coming from the pulley at idle. It sounds like a scraping noise and occasionally chirps but mostly a scraping noise at idle. I replaced the alternator belt when I did the installation but I did not replace the larger belt. I checked all belts and they are tight. I did not notice any wobble in the crank pulley and after the car was warmed up the noise was not as noticeable. Any ideas?? It is a scraping noise that goes along with idle and its coming from the crank pulley
Old Jan 30, 2009, 07:05 AM
Jehuty's Avatar
Might have some dirt behind the pulley, try some WD-40, with the hose of course, and spray it on the screw that holds it in place.
Huetsimus
Feb 17, 2017 08:23 AM
tim85851
11
Dec 10, 2011 09:42 PM
the_cosworth
Lancer Engine Tech
56
Aug 9, 2007 09:16 PM
_EVOlved_
151
Nov 26, 2006 06:04 PM
gldenchld
27
Apr 26, 2005 11:25 AM
Quick Reply: Crank Pulley Noise
