Safety Equipment Discussion (Seats, Harnesses, HANS, Rollbars/cages) [MERGED]
#241
Oops, twas wrong. Its 3rd gen bags that do that. The seat should still have a weight sensor though (at least the passenger should) so that it knows if someone is there or not for the seat belt warning.
#242
I can see weight sensor making sense in passenger seat. The assumption would be that there is always a driver, lol!
Buuuut, is it a weight sensor? I sure hope so granted a seat belt sensor seems to make more sense. If someone isnt wearing their seatbelt airbags are a big nono. I'd like to get to the bottom of this as I might have been driving around with no airbags the past few year. Its bad enough that my passenger side is shrapnel prone. If only I could convince the dealership to sell me the igniter so I could just do it myself ugh
#243
The passenger seat will have a weight sensor. If there is no weight in the seat, it won't trigger the seat belt alarm/reminder when the seat belt isn't clicked in. I've had a heavy box of part in pass seat that made it go off...lol
#244
I never even knew the thing would beep on the passenger side. But I also make sure to say "buckle up" right before I say "watch this!"
Lol! But actually now that I think about it, you must be thinking of your truck because I have harnesses on the passenger side too so the only times someone would be sitting there and not buckled up with the factory 3pts would be with harnesses on and it doesnt beep. I only disconnected the driverside seatbelt harness clip thing.
#246
I have a Sparco Pro ADV seat with Halo in my car and recently saw someone on another board post that they thought it was dangerous to use a halo seat without a helmet. The halo doesn't seem that hard to me (certainly softer than the side window or door frame!), but wanted to get others' thoughts? I know the Sparco Ergo with removable halo is out there, but that's not what I have, unfortunately.
#247
#248
#249
I'm not sure how likely it would be to hit your head on the door frame (then again, I'm short). LOL. If I had a choice of door/window or halo, I'd pick halo. At least I'd be more upright and, theoretically, have less velocity built up by the time my head hit it....?
I'm with you on safety stuff: On the street I use the OEM belt. I also have the OEM steering wheel so I have the airbag to work with the three-point. I only use the harness for track days.
tazio
Evo X How Tos / Installations
120
Jun 24, 2022 03:19 AM
TxFAkuma
Feb 28, 2017 07:41 AM
Nasty Evolution
Sep 16, 2016 03:03 PM
