2017 nasa st/tt/pt
Old Feb 1, 2017, 08:00 PM
Balrok's Avatar
God: Let there be Light!
Kyoo: But why is there light, and why does it have to be so bright, and does this heat mean anything?
God: Dude, light gives life to many things
Kyoo: Ok ya but this life thing i've heard can be hard, and you make it so bright I also heard that you can go blind staring at it?
God: ..... *lightening bolt*
couldn't resist
Old Feb 2, 2017, 04:56 AM
honda-guy's Avatar
Old Feb 2, 2017, 05:00 AM
honda-guy's Avatar
Originally Posted by kyoo
how does torque the lugs center the wheel? is it related to our lugs being mag style in any way?
aftermarket wheels use conical style lugnuts. when you torque something conical, it will center.
Old Feb 2, 2017, 06:12 AM
kyoo's Avatar
couldn't resist
lmao
I've honestly heard conflicting stories of some people melting their centering rings on track! wanted to check what the story was for evos
ah got it - guess i'll have to pick up some new lugnuts, I was just expecting to use the stock ones
Old Feb 2, 2017, 08:47 AM
killerpenguin21's Avatar
I've been running the same aluminum centering rings for like 4 years on track, no issues.
(Also been using bolt on spacers with no issues...but I'm sure I'll get flamed for that! )
Old Feb 2, 2017, 09:16 AM
kyoo's Avatar
which ones?
Old Feb 2, 2017, 09:36 AM
honda-guy's Avatar
you retard.
that is all
Old Feb 2, 2017, 09:44 AM
kyoo's Avatar
what about that is wrong? genuinely asking, I have no idea. bolt on spacers as opposed to what?
Old Feb 2, 2017, 10:38 AM
you retard.
that is all
Oh well. If I was running actual sticky tires id worry. It's on my list to change.
Old Feb 2, 2017, 11:02 AM
Balrok's Avatar
Google.
Good:
Bad:
Old Feb 2, 2017, 11:09 AM
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
Extended studs (ARP) and a slip on spacer are much preferred.
Get some Muteki SR48 lugs to go with your new wheels.
Old Feb 2, 2017, 11:17 AM
honda-guy's Avatar
just press out the studs on the spacers and use ARP studs. you dont need to get new spacers. let me know if you want me to order ARP studs for you
Old Feb 2, 2017, 11:24 AM
honda-guy's Avatar
with bolt on spacers, the spacers is bolted on to the hub, then the wheels is bolted on the the spacers. that just introduce more points of failure. most common thing that's ive seen is the spacers to the hub get loose, i've never seen complete failure though. but you can see how thin the lugnut seat is on the spacer, that just worries me.
Old Feb 2, 2017, 12:02 PM
heel2toe's Avatar
couldn't resist
Best thing I've read all day
Nope you need new lugnuts as mentioned
Great explanation. Also, what would bother me with having bolt on spacers is when it comes to heat cycles and retorquing things. You can easily retorque your lugnuts but how would you go about retorquing the nuts that hold on the spacer? That would force you to pop off the wheel to torque it down which would be annoying. So annoying means you wont do it. That is bad. Plus more studs more nuts more weight. Weight is bad.
Old Feb 2, 2017, 12:06 PM
kyoo's Avatar
didn't know I needed new lugs for aftermarket wheels - the "acorn" kind?
Quick Reply: 2017 nasa st/tt/pt
