CT9A Resurrection and Innovation
Old Mar 14, 2017, 06:13 AM
  #496
electron bom's Avatar
Originally Posted by Balrok
Once you get around to upping the kW aka torque and get nervous about the tcase there's a ginormous brace that Jon TRE assembled on several tcases for drag cars, it's on his facebook.
After a 3rd unanswered email with TRE, I gave up. I was pretty bummed about their non-existant customer service. I really wanted their 3.73 final drive in my gearbox.
Old Mar 14, 2017, 07:54 AM
  #497
Balrok's Avatar
No doubt . You gotta be tactical with him but the best is worth the wait usually.
Found it, may be only for DSM but worth a look:
http://frontlinefabrication.com/prod...er-case-brace/
Old Mar 15, 2017, 06:43 AM
  #498
Lights
Are wired and working, it was quite a process.
The body shop managed to get mud on the inside of a headlight cover, so I had to dissect and clean.
I bought some HID headlights from a member, but they came stripped. Here is a unit receiving all 5 bulbs, HID ballast, and a dust cover.
After ordering and installing a dash harness and headlight harness (long story), I have a satisfying result.
Old Mar 15, 2017, 08:45 AM
  #499
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
The tcase brace is only a DSM part. The Evo stuff stays together with the 10mm bolt upgrade, and proper gear setup that takes into account how the case flexes.
Gotta try a little harder with Jon. It's him and his apprentice in the shop, and that's it. And on top of he drivetrain work he does, he also has a CNC business. Pretty busy guys. If you are friends with on Facebook (Jon Ripple), you'll often see him posting work on the weekends. I've had good luck getting simple questions answered in FB messenger. Phone calls are usually best with Jon. But even then, sometime it takes a few tries to get him lol
Old Mar 15, 2017, 02:54 PM
  #500
V.8MR's Avatar
There is now a 3rd guy! If I remember correctly his name is Erik.
Old Mar 17, 2017, 09:12 AM
  #501
alex_s817's Avatar
I'm very interested to learn more about your EPS setup. Not sure I'd put one on my car right now, I actually like the feel w/o PS.
Ill shoot you a PM, have never seen it done on an evo before so Im excited to get it finished.
Old Mar 20, 2017, 04:16 PM
  #502
Working through the list of inspectable items
and not fairing so well
New reverse gear sensor on order
Old Mar 20, 2017, 04:24 PM
  #503
4G63_EVO's Avatar
I just replaced mine as well. Thankfully it's clean cut.
Old Mar 20, 2017, 04:27 PM
  #504
Had to get creative while bleeding clutch lines
Bleeding the QM hydraulic TOB has been interesting. I have been previously unable to eliminate all air bubbles. I installed a speed bleeder thinking that would remediate the problem, but it didn't. All lines and fittings were secure, no issues that I could see. So, I had to go into full blown diagnostic mode. I dropped the bleeder line into a test tube full of fluid. I then observed air bubbles coming from the line termination fitting itself With this new information, I was able to get some pedal pressure. Whether the leak still exists when the bleeder valve is torqued closed remains to be seen.
Old Mar 20, 2017, 04:39 PM
  #505
Cluster
After much deliberation, I decided it would appropriate to fabricate a custom instrument cluster.
I really wanted to keep the OEM cluster to maintain the 'Evo feel' of the interior. However, fabricating a bracket for a trigger wheel, sensor, etc. and affixing it to my motor wasn't something I was interested in undertaking to obtain a tach signal. I decided to purchase a speedhut analog tach (my controller utilizes an analog square wave for motor speed) and cut a custom cluster. This route probably involves just as much design, but better suits my purposes.
Here is the tach I ordered with a matching speedometer and motor temp gauge.
A rough idea of what my cluster will look like, based on OEM cluster dimensions and actual gauge diameters.
Old Mar 20, 2017, 04:42 PM
  #506
It's officially the last leg of the build
For the first time, the entire list of tasks can fit on one page.
7EVO7 (Mar 29, 2017)
Old Mar 20, 2017, 05:48 PM
  #507
BluEVOIX's Avatar
How will the twin motor setup look like ? Is it a inline/tandem setup or twin side by side ? Perhaps your looking to make two independent gear-less setup like the Tesla? One motor driving the front wheels and another motor independently driving the rear wheels..
Inline/Tandem :
Twin side by side:
Old Mar 20, 2017, 08:20 PM
  #508
I calculated the cost of building my own twin motor kit and it ended up only being about $400 cheaper than this really nice piece EVWEST did for an off-road baja buggy. This is what I'm leaning toward at the moment, should do something like 300hp/500tq with my controller.
Old Mar 21, 2017, 06:26 PM
  #509
BluEVOIX's Avatar
If you replace your controller , you can potentially make even more HP and TQ ?
So if I understand this correctly, the motors on these EV conversion can essentially can make more than the rated HP and TQ with the right controller , but for a shorter period of time or maybe if you rig something up to not have it over heat?
Also regarding your gauge cluster setup, couldnt you just use the OEM speedometer and customize the rest? If I’m not mistaken the speed sensor is in the transmission. Unless it requires you to use the ECU and doesnt have its own?
Old Mar 22, 2017, 04:44 AM
  #510
Yes, my controller is maxed out at about 350kW. There are other DC controllers that will handle much more power than that.
The manufacturer rates these motors by the amount of electric power they can withstand for 1 hour. They can handle MUCH more than their rated power for shorter intervals.
Yes, but running OEM and aftermarket gauges in the cluster wouldn't look very clean IMO.
Quick Reply: CT9A Resurrection and Innovation
