Tim's Evo 9 SE build. From Stock to 2.2themoon
Old Dec 19, 2015, 06:06 PM
Thrilla's Avatar
Nice work with the evo and documenting your journey. Excellent and purposeful build!
Old Dec 19, 2015, 09:42 PM
deeman101's Avatar
You're using a brand new evo 9 core with oem bore etc? With 85mm pistons and 94mm stroke you're actually closer to 2.1L. 2132cc to be exact. Results should be good regardless though.
Old Dec 20, 2015, 08:40 AM
Kevo_58's Avatar
in for updates
Old Dec 21, 2015, 08:59 AM
Abacus's Avatar
I was aware of that. I work with numbers each day and I like to round up where I can. Plus 2.2themoon sounded better then 2.1overthehill. LOL
I'm looking forward to the results as well.
kizzlecake (Jun 6, 2019)
Old Dec 24, 2015, 01:19 PM
Abacus's Avatar
New engine is in and running. Santa came early!
Old Dec 25, 2015, 01:37 PM
Erik@MIL.SPEC's Avatar
Nice. Looking forward to new dyno charts, which will give me a great idea for what mine will do
Old Dec 26, 2015, 01:32 PM
Abacus's Avatar
Me too. As long as backpressure doesn't get out of control both engines should make good power with a solid tune.
On my stock engine/cams and 2.75" DP my car would make 37psi of backpressure at 30psi boost. I will be testing back pressure on this setup as well. I'm hoping it has a similar curve to the 615/477 run .
I've got 125 miles on the new engine on pump gas and it feels as good downlow/part throttle as the stock engine with the stock intake manifold did on Ethanol. When the skunk2 was installed on the 2.0 it lost some of the response/snap that it had on the street.
Jay M spent a few minutes on the idle and its pretty good. He knows the Infinity well and with live changes you can see and feel results instantly.
The new engine runs smooth but you can tell its serious. Exhaust note is much louder then before and the car vibrates a little more.
Old Dec 26, 2015, 02:40 PM
On my stock engine/cams and 2.75" DP my car would make 37psi of backpressure at 30psi boost. I will be testing back pressure on this setup as well. I'm hoping it has a similar curve to the 615/477 run.
How hard is it to put a pressure sensor on the turbo? I may do that for fun just to compare.
Old Dec 26, 2015, 05:24 PM
Abacus's Avatar
You can measure backpressure via the egr port, or the exhaust with a 4-5 bar sensor or a guage. When will your car run?
Old Jan 22, 2016, 08:15 PM
Abacus's Avatar
Added new dynograph to post #4. Still more tuning to do but it runs really well!
Old Feb 9, 2016, 02:21 PM
Abacus's Avatar
Added the wannagofast runs to post #4.
Old Feb 10, 2016, 03:07 AM
Jonno99's Avatar
This wOuld have to be one of the best pictorial threads I have had the pleasure to read
Old Feb 13, 2016, 11:53 AM
Abacus's Avatar
Thank you Sir. The car is an absolute blast to drive now! The Fp red/2.2 and 4.11 make for a well balanced streetcar.
Old Feb 17, 2016, 08:14 PM
NexusEvoIX's Avatar
Dream build. +1
Old Feb 22, 2016, 06:52 AM
Abacus's Avatar
Originally Posted by NexusEvoIX
Dream build. +1
Thanks man! Drove the car 320 miles round trip to jacksonville this weekend at 70-80mph. Managed 22mpg on E85 on the way up and 25mpg on the way down on pump gas. Fwiw, it used to cruise pretty easy at 70mph and now its 75-77mph. The 4.11 Final drive and evo 8 gearing puts it around 3000 @80 so its really nice on the highway.
<a href="http://s1288.photobucket.com/user/tim_meagher1/media/Mobile%20Uploads/image_zpsr1zmu1mc.jpg.html" target="_blank"><img src="http://i1288.photobucket.com/albums/b495/tim_meagher1/Mobile%20Uploads/image_zpsr1zmu1mc.jpg" border="0" alt="Feb 21st ,trip to Jacksonville and back. photo image_zpsr1zmu1mc.jpg"/></a>
Quick Reply: Tim's Evo 9 SE build. From Stock to 2.2themoon
