Water-Meth Q&A (Labonte)
Old Mar 28, 2008 | 02:05 PM
Labonte MotorSports's Avatar
Hello EvoM Members,
There is a lot of good info on this forum about water/meth injection posted by members knowledgeable in the subject. For those of you that are new to the subject, I have put together the below information to help explain some of the principles involved with water-meth and answers to some of the more common questions we get.
I hope that some of you will find the below information beneficial. If you have any questions please post them and we would be glad to help.
History:
First off water-methanol injection is nothing new. Water Injection was first successfully implemented in WWII on the P-47 “Thunderbolt”. The Turbo Charged Pratt & Whitney R-2800 engine normally produced 2000 HP, with water injection the engine could produce up to 3800 HP. With water injection, the P-47 had 20 minutes worth of high power output for combat situations. One initial problem was that at high altitudes the water would freeze. So to prevent freezing, methanol was finally added to the injection mixture. Later studies done by the Army Corp of Engines actually determined that with a 50/50 mix of water-methanol even more power could be produced over water injection alone.
On Demand Octane Boost:
Octane is simple a measure of a fuels ability to resist spontaneous combustion, also known as preignition. Due to high temperatures and pressures associated with forced induction, a fuel might ignite before the spark event. This results in a very fast flame and extreme combustion pressures that can destroy an engine. The higher the fuel octane, the slower the fuel will burn and less chance of preignition.
Engine knock is actually different then preignition. Knock is the result of the spontaneous combustion of left over gasses in the cylinder. The engine damaging effect is similar to preignition.
Higher octane will not make more horse power by itself. If an engine is tuned for 93 octane, and C116 race fuel is added to the tank, the engine will not make more power simply from the different fuel. If the engine is tuned for C116, then more power can be made, either by more spark advance or more boost. Problem with C116 is one, it is expensive, and two you are wasting that high octane fuel at idle or low engine loads when it is not needed.
The octane rating of water is infinite. It can’t spontaneously combust as you can’t burn water. Methanol is also a high octane fuel in itself. Here are some octane ratings of various fuels:
Chemical / RON / MON
(The octane number you see in the US is [RON + MON]/2)
Methanol / 133 / 105
Ethanol / 129 / 102
Isopropyl Alcohol / 118 /98
MTBE / 116 / 103
Toluene / 124 / 112
Meta Xylene / 164 / 124
Dicyclopentadiene / 229 /167
As a rule of thumb, 50/50 Water/Methanol injection will increase the octane rating of pump gas by 25% during injection. (Note that C16 Race gas is already 116 octane, W/M will slow flame more). So with a load based injection system, you only get the octane increase when needed.
Water is capable of cooling the combustion chamber more efficiently then gasoline. Water has a higher Latent Heat of Vaporization then gasoline. When water is injected in very small droplet sizes into the combustion chamber, it readily absorbs heat as the partials go from liquid to gas state. The water particles actually “pop” or create multiple micro explosions. These micro explosions help to slow the flame front, effectively increasing the octane rating. These micro explosions also help to “stir” the air fuel charge or create a swirl effect in the combustion chamber. This swirl effect results in a more complete combustion of the fuel, leading to lower NOx emissions. With a more complete combustion, engine knock is reduced. This is due to the lower amount of gases available after combustion that can spontaneously combust.
Air / Fuel Ratios:
A gasoline engine will make the most power at an A/F of 12 to 12.5 to 1. The problem is that at this lean of A/F ratio, a forced induction engine will have a tendency for preignition when using regular octane pump gas. That is why most forced inductions engines are tuned for an A/F of around 11.5/1. At 11.5/ 1, 10-15% extra fuel is being added to cool the cylinder and top of the piston to prevent preignition. This extra fuel is not burned in the combustion process and goes out the tail pipe.
A 50/50 mix of water-methanol, when injected in the right quantity, will lower A/F by at least ½ point. Now the engine fueling can be reduced, more timing added, or more boost can be added allowing the engine to make more power.
Chemical Intercooling:
Most water-methanol injection systems are designed to spray the injection mix after the intercooler and before the throttle body. These systems are designed to inject the mixture with a high pressure pump and fluid atomizing nozzle. The smaller the injection particles, the more surface area there is of the small droplets, and the more heat that can be removed. As mentioned above, the high Latent Heat of Vaporization of water lowers in the Intake Air Temp as the water absorbs heat going from a liquid to gas state. A cooler air charge reduces the chance of pre-ignition allowing for more timing or higher boost levels.
An intercooler does the same thing to lower air charge temperatures. One draw back of an intercooler is the boost pressure drop across the intercooler. A second is that in an air to air intercooler, cooling efficiency is limited to that of ambient air temperatures. A third draw back is cost and weight of large front mount intercoolers.
Injection Fluids:
The most common question we get is “Where can I buy Methanol”. Most are surprised to find out that everyday window washer fluid is nothing more then water and methanol.
When using window washer fluid for injection, look for these items to insure you have a good product.
  • The fluid is Blue
  • The label says protects to -20 or -25F
  • No soap bubble form when you shack the bottle.
Note you want to avoid mixtures that contain propylene glycol (anti-freeze). This is commonly added to window washer fluid to lower the temperature rating and is harmful to the engine if injected.
Here are some methanol ratios of commonly available washer fluids per the manufactures MSDS.
Old Mar 28, 2008 | 03:33 PM
C6C6CH3vo's Avatar
What exactly does propylene glycol do thats harmful when sent into combustion? I here this alot but haven't found the reason yet.
Ethylene glycol bad too?
Old Mar 28, 2008 | 03:42 PM
SlowCar's Avatar
glycols is an ingredient in commercial "smoke" machines...i guess the exhaust will be smoking if it is used
Old Mar 28, 2008 | 03:46 PM
SlowCar's Avatar
1 suggestion...i think you should give credit to the authors of the info above
a link to where you got the info from should suffice...plagiarism is not right
Old Mar 28, 2008 | 07:54 PM
C6C6CH3vo's Avatar
My son has a smoke machine, it cost $30 a gal of fluid. I guess I can make my own now
Old Mar 28, 2008 | 08:44 PM
SlowCar's Avatar
make sure you use propylene glycol...
http://chemistry.about.com/od/howthi...machines_3.htm
Old Mar 28, 2008 | 09:13 PM
Glycol will form a chemical bond with other hydrocarbon molecules resulting in the formation of polymer chains. What you get is a sticky build up over time. Also silicates are used in antifreeze as a corrosion inhibitor. When the 02 sensor is continually exposed to these silicates it will result in premature failure of the sensor.
Old Mar 28, 2008 | 09:22 PM
Thanks SlowCar, it was that well written?
Old Mar 28, 2008 | 09:44 PM
ChuckP's Avatar
Very interesting, thanks!
Old Apr 1, 2008 | 05:26 PM
C6C6CH3vo's Avatar
I think he gave you a B- for the report due to lacking bibliography
Old Apr 2, 2008 | 06:46 AM
SlowCar's Avatar
"F"
Old Apr 6, 2008 | 10:54 AM
jpetro10's Avatar
so if you wanted to buy straight methanol or as close to it as possible would you buy HEET?
Old Apr 6, 2008 | 12:21 PM
cpoevo's Avatar
No, buy VP M-1 Methanol. You can buy it anywhere that sells VP fuels, I pay $35 for 5 gals a hell of a lot cheaper than 5 gals of Heet.
Old Apr 11, 2008 | 12:18 PM
Armdrop Live (Labonte Sponsorship)
Labonte MotorSports is pleased to announce being selected as the official Water-Methanol Injection sponsor of Rich Christensen’s Armdrop Live.
From the Creator of PINKS, Pinks All Out, Pass Time and Drag Race High, Armdrop Live adds a new dimension to bracket racing that is sure to challenge even the best of drivers.
Armdrop Live is not about how fast you can build a car. Armdrop is about how accurately you can make your ride perform. At each track racers will put their skills to the test to win up to $10,000.
For the latest information and track schedules visit the Armdrop Live website at Rich Christensen's Armdrop Live
Labonte MotorSports wishes all racers a safe event and the best of luck, your going to need it.
The Current Armdrop Racing Schedule:
May 16-17 Immokalee, FL Immokalee Regional Dragway
May 30-31 Edmonton, Canada Castrol Raceway
July 4-5 Portland, OR Woodburn Dragway
July 11-12 Toronto, Canada Toronto Motorsports Park
Oct 10-11 Tulsa, OK Tulsa Raceway Park
Nov 4-5 Las Vegas, NV Las Vegas Motor Speedway
Nov 7-8 Irwindale, CA Irwindale Raceway
Old Apr 18, 2008 | 11:16 AM
leecavturbo's Avatar
that info in the first post is worthy
of this thread being a sticky
