Water-Meth Q&A (Labonte)
Old Jul 3, 2008 | 11:05 PM
  #46
krazirob's Avatar
yes aquamist came with a detailed instruction on how to set the system up once its already installed......
would be great to get that kind of knowledge.....
for instance everything is working on our car and she is spraying on certain boost level but gettin the failsafe and everything to work properly has been in PITA.....
please at least let us know exactly what the three adjustments on the boxes do!!
Old Jul 4, 2008 | 08:46 AM
  #47
Labonte MotorSports's Avatar
krazirob -
Do you have the User Guides for your system and the Fail Safe? Both come with color User Guides that tell how to set up the system.
Here are some inital Set up points
Controller:
Start Dial set to 1/3 of max boost
Full Dial set to max boost
Fail Safe:
Set trip point to 1/3 of max nozzle flow
M6 = 150ml/min
M8 = 200ml/min
Let me know if you still need help getting things set up.
Best regards,
Dan
Old Jul 4, 2008 | 09:57 AM
  #48
ddillard424's Avatar
Originally Posted by Labonte MotorSports
krazirob -
Controller:
Fail Safe:
M6 = 150ml/min
M8 = 200ml/min
Best regards,
Dan
dan on the fail safe you sent back to me you set the fail safe at 200ML/Min... in this post you have that listed for the M8 nozzle.... im using the M12 nozzle shoudnt that trip point be higher for a bigger nozzle?
Old Jul 4, 2008 | 04:10 PM
  #49
krazirob's Avatar
i didnt get that detailed instruction with the kit......
we will try this though and see what happens......
Old Jul 5, 2008 | 09:02 PM
  #50
Yes you are correct, did not remember you installed the M12. Set Trip point to 300ml/min when you get it back.
Best regards,
Dan
Old Jul 6, 2008 | 08:30 AM
  #51
Nood1es's Avatar
i have the labonte meth with m12 nozzle the trip is at 250 is it a neccesity to set it to 1/3 of flow...or could i just leave it?
Old Jul 6, 2008 | 09:37 AM
  #52
tweaker41's Avatar
The max flow rate of the M12 nozzle is 925ml/min which means your trip point should actually be around 308ml/min. I would turn it up just a little but I don't think it's that much of a necessity.
Old Jul 6, 2008 | 04:34 PM
  #53
Nood1es's Avatar
cool thanks tweak.
Old Jul 6, 2008 | 05:38 PM
  #54
tweaker41's Avatar
No problem. How much power are you putting down to the ground that they recommended the M12 nozzle?
Old Jul 17, 2008 | 04:55 AM
  #55
EVIL MR's Avatar
How long your pumps last using 100% meth??
Old Jul 18, 2008 | 06:20 AM
  #56
The pumps we sell have the upgraded EPDM values to be compatible with 100% meth. We have yet to have any come back due to faulire from meth.
Old Jul 18, 2008 | 08:14 AM
  #57
EVIL MR's Avatar
This guy Dan is the man. He was helping me all morning with what I thought was the pump on it's way to die. Come to find out that my fail safe I got from Snow performance was leaking very bad all over. So I got me LABONTE MOTORSPORTS fail safe on the way. Thanks Dan
Old Jul 26, 2008 | 07:05 AM
  #58
Owens Racing's Avatar
Having issues with my Fail Safe Solenoid. I have had this hooked up per the instruction that came with it as well the new instructions. I get wastegate boost every time. I can bypass the noid and it is Rocking full boost.
Any chance I got a bad noid?
I also used a third port on my EBC noid (it appeared to not have a plug) this was how the new instructions said to hook it up.....are these third ports plugged when not used? If so then this could be my issue right now. Would really like to have a failsafe working when running big boost.
Old Jul 26, 2008 | 07:54 AM
  #59
yep mine is doing the exact same thing!!! even with the trip point dialed in
Old Jul 27, 2008 | 06:43 PM
  #60
Noids are very reliable so little chance it is bad, but not impossible. Have seen a few Evos where GM noid traps boost between WG and port A such that it keeps you in safe mode on some MBC. Call me when you have a chance and will trouble shoot your set up.
Best regards,
Dan
