02-03 Lancer Show / Shine Post your pictures, photoshops, and videos!
MISOSLO's 02 OZ Rally Build
Old Aug 20, 2011 | 11:44 AM
  #61
rtekc's Avatar
Old Sep 7, 2011 | 03:07 PM
  #62
rtekc's Avatar
*image link broken*
Old Nov 24, 2011 | 10:18 AM
  #63
BCMason's Avatar
what are the rims on the MR2?
Old Nov 25, 2011 | 08:13 PM
  #64
rtekc's Avatar
16x7 Rota Boosts
Updates: Swapped the headlight bulbs in the Depo Projectors with PIAA Xtreme White Plus H7 bulbs. Simple plug and play. The light is less yellow compared to the bulbs that came with the headlights. I also installed an Injen Hydroshield on the Fujita Cold Air Intake filter.
Old Jan 19, 2012 | 07:58 AM
  #65
rtekc's Avatar
Old Jan 30, 2012 | 06:43 PM
  #66
limp_noodle's Avatar
Looks good. You should get some amber side markers.
Old Feb 7, 2012 | 11:29 AM
  #67
Chris D.'s Avatar
Originally Posted by rtekc
Depo Evo 7 Tail Lights
*Edit* Bought and Installed Bosch Icon Wiper Blades (Part 424A and 418A). 24" on the Driver's Side, 18" on the Passenger's Side.
I had a set of Evo 7 factory taillights and they were wider than the opening on my 02 Lancer ES..
So are yours Evo 7 style aftermarket made for the 02-03 specifically?
The 1/4 panels rearward of the door on the evo 7 are kicked outward a bit..
just curious..
Old Feb 10, 2012 | 09:04 AM
  #68
rtekc's Avatar
I thought the clear corner signals matched with the top of my headlights, just like the amber reflector matches with the bottom of my headlight.
Depo Evo 7 Style Tail Lights. Real Evo Headlights/Tail Lights won't fit.
Been debating the past week if I want to build up a clean JDM Integra Type R with a cheap GS-R. They're a little tough to find unmolested though.
Old Feb 12, 2012 | 09:29 AM
  #69
i.Apotheosis's Avatar
just curious..
Yes, ebay ones I believe.
Old Feb 12, 2012 | 09:56 AM
  #70
Ok, so after looking through these pics I can't figure out whether you changed your shift knob or if the pictures distort my perception. I like the first pic of the metal knob with a metal spacer below it (if I am seeing correctly), but in the other pics it looks like your knob is dark/painted/leather and the metal spacer is gone.
I like the evo setup with a aluminum spacer. Maybe getting the look is easier than I am aware of, but I'd like that look with a metal or leather wrapped ball.
Old Feb 21, 2012 | 09:39 AM
  #71
rtekc's Avatar
I had a Greddy Shift Knob (very heavy) for awhile with the stock shifter. It was ok, but was hot/cold to touch depending on the weather we get here. No metal spacer under there. That was just the top of the shift knob boot, which is very shiny.
I upgraded to rare Mitsubishi Short Shift Kit, which came with an Evo 8 leather wrapped shift knob. It's very lightweight, but gets the job done. Mitsubishi doesn't make them anymore, but if you call around to enough dealerships, you may find one.
*Status Update* Upgraded the headunit to an Eclipse single din DVD + Nav headunit. It seems like the new Lexus navigations are based off of Eclipse cause the voice is the same! Integra plan is on hold cause the Spyder is in the shop for an upgraded brake overhaul and then off to the paint shop for some touch ups in time for car show season.
Old Feb 22, 2012 | 07:42 AM
  #72
BCMason's Avatar
Off topic a bit but I have a feeling you might be able to answer my question. I'm looking for black carpet for my car do you or does anyone know of where I could get some that is moulded already or will I just have to buy some and cut to fit?
Old Feb 22, 2012 | 07:47 AM
  #73
BCMason's Avatar
If possible could you post more pictures of your tail lights they look amazing painted to be like the Evo's
Old Feb 22, 2012 | 08:12 AM
  #74
BCMason's Avatar
Whoops never mind I'm dumb I just saw them on RRM
Old Feb 22, 2012 | 08:43 AM
  #75
rtekc's Avatar
Black Carpet: Junkyard (although Lancer's aren't as common as Integras at the yard. Plus the quality won't be that great). You could also take it to an upholstery shop. I wouldn't try making it yourself because of all the forming you would have to do.
Evo 7 "Style" Lights: You can get them on eBay cheaper than RRM if you look long enough.
