remote turn on?
Old Feb 2, 2005 | 10:49 AM
miltown RA's Avatar
Question remote turn on?
for those of you using the stock head unit to run amps what did you use for your remote turn on lead
Old Feb 2, 2005 | 10:26 PM
bbradj's Avatar
What I did when I was running on stock was I used a switch (any switch from pep boys, autozone, orielly) and ran the pos+ to the amp pos+ and ran the neg- to the amp neg- so I could turn the amp on and off. You can also use a pos+ wire from the ignition ( i think never done it)...I always liked the switch so when the wife was in the car I could keep the bass off. Hope this helps.
Old Feb 3, 2005 | 03:05 PM
otter's Avatar
EvoM Administrator
You could also run the remote wire from an ACC slot on the fusebox, so the amps come on when the key is turned, and you wouldn't have to worry about forgetting to turn off your amps.
Old Feb 3, 2005 | 06:25 PM
pinoynoskillz's Avatar
yeah but iff its in the ACC.. when you dont wanna listen to your radio.. your amp is still on. i tried it. its not good. =O
Old Feb 3, 2005 | 06:51 PM
Red Dragon's Avatar
find the remote turn on led wire in the headunit and attach it to the amp remote turn on.
Old Feb 3, 2005 | 09:10 PM
miltown RA's Avatar
wiring diagram anyone????????????
Old Feb 4, 2005 | 12:25 AM
Myszkewicz's Avatar
My diagram sucks. It shows the power wiring for the radio and amp, and the speaker wiring, but doesn't show the wire that goes between them.
Old Feb 4, 2005 | 06:29 AM
sillypuddy's Avatar
you don't want to use the backlight wire.. trust me..
it's variable voltage..
-joe
Old Feb 4, 2005 | 06:36 AM
if your HU has a "AMP ATT" wire.. connect that with the wire running to your amp. then when you turn your hu on the amp turns on. its what i did. =O.
Old Feb 4, 2005 | 11:24 AM
miltown RA's Avatar
is this wire on all the radios or just the s&s packedged ones will search for it today
Old Feb 4, 2005 | 12:30 PM
otter's Avatar
EvoM Administrator
The stock amp most likely does not have a remote wire (usually blue). The stock amp probably just turns on with detection of a signal. When I get home I'll see if I can find a diagram of the stock amp wiring.
CeliOnce
Apr 2, 2018 07:44 PM
CeliOnce
Mar 5, 2017 08:37 AM
05-EVO-GSR
Aug 25, 2015 08:45 PM
Solofantasy
Lancer Troubleshooting
Sep 26, 2009 05:01 PM
Reboot
May 13, 2008 06:09 PM
