Removing Dash Board and Centre Counsel
Old Apr 11, 2005 | 09:54 AM
Badgerman's Avatar
Question Removing Dash Board and Centre Counsel
Need some help on how to remove both of these.
I had a security system installed and the guy ran the wire under the dash by the windshield and just stuck the light out in the middle of the dash by the glass. There is a plastic piece that pops out in the middle of the front vent that looks like a good spot for this but I could not fish the wire through. Is there a way to remove the dash so I could do this.
For item 2, when I installed my new stereo I dropped a socket. Can someone please let me know who to remove this so I can get it ?
Old Apr 11, 2005 | 11:25 AM
403RA's Avatar
Exclamation
Item 2 can be found by using the search, I know I found it before. You may also find info for the dash using the search. FYI, for the most part EVO/RalliArts/OZs have the same interior.
Old Aug 9, 2005 | 01:09 PM
jdizzy's Avatar
To remove the center console you have to remove two screws inside the compartment under the armrest... then pull the ebrake up and remove the armrest section... then you will see two more screws holding the shifter panel section... remove those and one screw under the ashtray... then two pop-it fastners up towards the front by your feet under the panels attached to that section... then take the shift knob off and left the shifter panel section up and out... there you go... as for the dash I'm sure they didn't take it off so you can probably just pull the wire around the dash and take it out... they did the same thing with mine and that's all I did... unless you really want to take apart your dash cause it's not easy... have fun!!
TrogdorWBL
65
May 3, 2016 02:38 PM
STIU2SLO
Feb 2, 2016 10:48 AM
211Ratsbud
Dec 11, 2013 05:17 PM
Fireball
10
Mar 1, 2012 01:04 PM
honda-guy
Feb 4, 2012 01:47 PM
