DIY solid motor mounts - a different approach
Old Nov 6, 2005 | 10:13 PM
Myszkewicz's Avatar
Originally Posted by DallasN2O
Very cool. Where did you pick up the new mounts? Dealer?
Yep, dealer.
Have you gotten used to the vibrations yet or installed the rear mount?
Haven't installed the rear mount yet, still debating if I want to keep them this hard or go with some softer urethane. I don't know how many times I want to pull and install motor mounts to find the right balance.
As far as that goes, anyone want some REALLY solid motor mounts?
Old Nov 15, 2005 | 12:35 AM
DangerousDan's Avatar
Absolutely. I could either purchase your excellent job or use your even better DIY to do this myself. I was waiting to purchase solid urethane mounts because people were reporting the window weld failure after awhile, now I don't have to. Let me know if you def want to sell those mounts.
Old Dec 22, 2005 | 01:32 PM
mitsutech005's Avatar
Thumbs up
awesome diy. i plan to follow your lead now instead of buyin them. i had heard of some of my dsm pals using hotglue to fill it all in but they said they broke after a while. will prolly be doin this in jan after my new clutch gets here. major props on this one!!!
Old Sep 27, 2007 | 11:25 PM
LithiumX's Avatar
when we talk about front and rear motor mounts we mean front is toward the radiator the one onteh bottom and rear is the one towards teh firewall ???
Old Sep 28, 2007 | 11:26 AM
Cow town racer's Avatar
Ya those are the two there both attached to the tranny, the front one is located on the crossmember and the other one is on top of the axle.
Old Nov 28, 2008 | 07:36 PM
lucky04's Avatar
where are you guys finding the flexane mix at? are you getting it from the net or local parts store, because none around me seem to have it
Old Mar 6, 2011 | 10:24 AM
mmoulton470's Avatar
Would it be a bad idea to fill the transmission mount as well? I have solid motor mounts but I noticed my transmission mount is broken, so I am just curious as to whether I should just buy an oem mount or if it would be beneficial to fill the tranny mount.
Old Mar 6, 2011 | 01:14 PM
lanzerralliart's Avatar
EvoM Super Moderator
I'd think it would help, I've thought of this as well but I haven't done it.
Old Mar 6, 2011 | 03:19 PM
I may try it then. It definitely won't damage anything will it?
Old Mar 6, 2011 | 04:17 PM
I don't see it doing any harm , they make kits for the evos and tons of other cars.
Old Mar 7, 2011 | 06:42 PM
CrAnSwIcK's Avatar
Acklands Grainger carries Devcon products...not sure if you guys have that in the states
BoostNY
Feb 23, 2017 11:43 AM
mrfred
Jan 28, 2017 09:58 PM
blk-majik
Jul 20, 2015 08:18 AM
RussellM
Mar 16, 2012 09:27 AM
Myszkewicz
Oct 24, 2005 07:52 AM
