head unit installation
Old Jun 26, 2006 | 08:46 AM
  #61
djnry's Avatar
everyone thanx again for replying
kmcconn9 do you work for CC by any chance and thanx for that letter diagram that you rigged up...gave me a better picture on what's going on
now things are starting to shape up and have a plan to do this
to summarize i need 3 adapters for this project
1) metra 80-7001 harness = power
2) Soundgate adapter = to use the stock amp
3) radio harness that matches my new HU
now what is that black single long wire on the metra 80-7001 harness and where does it hook up?
http://www.circuitcity.com/ssm/Metra...oductDetail.do
Old Jul 21, 2006 | 12:25 PM
  #62
Plt Daddy's Avatar
this guy is confusing the $hit out of me . Here is what I gather after reading 4 pages. Please correct me if Im wrong.
My situation:
I have an EVO with SSL and want to keep all the wiring all the speakers and the factory SUB and AMP
I want to get another head unit
I need this: Metra Vehicle Wiring Harness (80-7001)
MET 807001
Mitsubishi Radio Replacement Part # MITSRCVR SoundGate's MITSRCVR allows new receivers or CD players to be installed in Mitsubishi vehicles equipped with the "Infinity" sound system. MITSRCVR's DIN connector allows new receivers or CD players with RCA outputs to be simply plugged into the vehicle's amplifier cable.
Product Documents:
click for larger image
$26.95Part # MITSRCVR
Is this right??
thanks in advance
Old Jul 21, 2006 | 05:41 PM
  #63
DangerousDan's Avatar
Looks like it to me.
Old Jul 21, 2006 | 05:43 PM
  #64
btw, I have the stock radio in my lap and if that is an actual picture of the cable they will send you then yes they match.
So like I said, looks like it to me.
Old Jul 22, 2006 | 09:51 AM
  #65
Plt Daddy's Avatar
thanks
Old Jul 22, 2006 | 10:24 AM
  #66
morpheus256's Avatar
a cheaper solution would be to get the metra 70-7003 harness, in includes both peices above, and is cheaper in the end.
http://www.amazon.com/gp/product/B00...lance&n=172282
Old Jul 26, 2006 | 01:30 PM
  #67
Plt Daddy's Avatar
A$$ kicked
OK I got my new HU (Pioneer AVHP5700DVD) and my metra cable 7001 and the
I was going to try to do this myself but I was overwhelmed when I saw all those cables. I tried to connect them but the white end on the metra cable 7001 does not fit my new HU.
Old Jul 26, 2006 | 02:51 PM
  #68
Myszkewicz's Avatar
I assume your new HU came with its own wiring. It plugs into the back of the HU and has wires between 8 and 12 inches long, which terminate in stripped ends. I also assume that the HU has RCA jacks on the back for pre-outs.
Now, the Metra 70-7003 adapter (or the Soundgate adapter and whatever other adapter), used in conjunction with the new HU's wiring, will enable you to just plug the new HU into the car's wiring.
Plug the single, round DIN cable into the cable that goes to the stock amp. Plug the 4 RCA plugs into two sets (front and rear) of RCA jacks on the back of the HU. Also connect the single thin wire from this cable to the remote turn-on wire from your HU.
Match up the wires from the other part of the Metra adapter to the wires that come out of the back of your new HU. Battery power, ACC (switched) power, illumination, are the important ones. Ground is best run directly from the HU to chassis ground.
Plug the adapter into your car's wiring under the dash, plug into your HU, plug in antenna wire, and put the HU in the dash. Done.
If I have to, I can pull out my HU and take good pics of my wiring.
alexc
11
Sep 29, 2015 03:44 PM
jake33
Jun 9, 2015 02:34 PM
llDemonll
24
Feb 18, 2013 10:50 PM
MavenIX
17
Oct 6, 2011 08:38 PM
Tadz0rz
Feb 9, 2009 04:55 AM
