Speakers randomly stopped working
Old Jun 8, 2015 | 09:58 AM
jake33's Avatar
04 SSL Evo, I have a Clarion head unit with the MITAH adapter for the stock amp. Thought the amp crapped out, replaced it, still no sound from speakers. Headunit is working fine, just no sound or white noise or anything from any speaker. Any ideas?
Old Jun 8, 2015 | 10:02 AM
jakeleclair2000's Avatar
Are you outputting signal from the head unit through the RCA jacks or speaker leads?
Old Jun 8, 2015 | 10:48 AM
jake33's Avatar
Rca
Old Jun 8, 2015 | 11:03 AM
Ok, so if you have access to a multimeter, you can test the RCA jacks to see if you're outputting signal.
Disconnect all RCAs
Select an audio source, FM or CD works great for this, and turn up to 3/4 volume.
Set Multimeter to measure AC current, put 1 probe into the center of the RCA jack, and the other probe on the outer ring of the RCA jack.
IF signal is being output through the RCA jack, you will see the AC voltage on the meter fluctuate. Voltage level should go up and down with volume.
Test all RCA jacks like this, and if all pass, then the radio is good and signal is being outputted appropriately.
The next thing to look at is the adaptor harness. Identify which wires carry audio signal from the harness to the amp and test those the same way as the RCA jacks. 1 probe in the + signal wire and 1 probe in the - signal wire. (Make sure you're testing the same channel + & - or it wont work).
You can also test for audio signal after the amp or at the speakers using the same method.
Find out where the audio signal stops, and that is most likely your problem.
Old Jun 8, 2015 | 11:05 AM
Also not a bad idea to double check +12v power, ground and remote turn on before testing for signal.
Rule out the simple things first
Old Jun 8, 2015 | 11:59 AM
BlackHawk_Tsi's Avatar
Remote turn on is usually the culprit. Symptoms usually looks like a bad amp.
But also a friend of mine had a similar issue with a VW Passat. I found a wire pinout in a harness that was loose. I pushed it in, put a droplet of 5 epoxy and it worked.
happy hunting!
Old Jun 8, 2015 | 12:06 PM
duplicate
Old Jun 9, 2015 | 02:34 PM
Januch09's Avatar
chcek your fuses and inputs/outputs connection
newimportowner
Sep 26, 2011 10:53 AM
prowakeskater
May 11, 2011 03:57 PM
ralli_DC
Jun 8, 2007 11:16 AM
RunEvo
May 11, 2007 07:05 PM
BensLancer
Lancer Troubleshooting
15
Oct 10, 2005 11:51 AM
