Master cylinder leaking (WEIRD)
Old May 20, 2008 | 01:33 PM
bruce988jl's Avatar
Originally Posted by DangerousDan
do you have the SS clutch line or slave mod delete done? are you rev matching when down shifting? also, it will lock you out if you are significantly beyond the speed capable in that gear
going into gear is just one of those things inherent in this tranny, but I've not had an issue since I have the motor mounts, both sets of shifter bushings, modulator delete, and clutch block. that's a pretty solid connection, you can literally feel what you are doing nothing "moves", so even during moderate cornering it shifts smoothly. I'll encounter some resistance every now and again coming out of a hard corner having to shift, but I think the proper suspension would alleviate most of that as well.
Hm... yea I think my motormounts are shot... I have stock clutch lines right now, have an upper waiting to be installed and will be doing the modulator fix soon enough. I'm waiting on a reply for motormounts as well, or i might just fill mines.
Old May 20, 2008 | 05:42 PM
DangerousDan's Avatar
all of those things contribute to engagement issues, especially under hard acceleration. mounts were one of the earlier things I did. huge difference in the whole attitude of the car
Old May 21, 2008 | 05:20 AM
bruce988jl's Avatar
Yea someday i'll fill mines. I've just been so tied up that the only time I actually get to romp on the car anymore is on the on/off ramps on my way to/from work. Otherwise I drive fairly slow since my highways are pitted with staties.
I check my MC again and it still looks clean from the last time i checked it out. I'm still trying to figure out where that ticking is coming from, I think I might drive around saturday for a while before i do my timing belt and just let the car idle while its on the lift and try to isolate the noise from down under.
lasthero32
Apr 28, 2015 12:04 PM
MyRoN
14
Jul 18, 2007 04:19 PM
MyRoN
Jan 6, 2007 01:31 PM
MyRoN
15
May 24, 2006 02:32 PM
MyRoN
04-06 Lancer Ralliart How To Requests / Questions / Tips
Apr 12, 2006 12:54 PM
