Lancer Mini Battery kit install
Old May 29, 2007 | 09:55 PM
ThyPunko_PR's Avatar
This is the install of the PPI Lancer Mini Battery kit:
Tools needed:
10mm open wrench
8mm Allen
6mm Allen
5mm Allen
Red Loctite (271 or 277)
1st: Remove the 0EM battery.
2nd: Remove the plastic tray: take care of removing the rubber line attached to it. There is also a plug attached to the lower corner of the tray. This will be a good time to clean the area below the tray.
3rd Install the lower part of the mini battery tray with the provided adapters using the 8mm Allen, you will use the two big holes were the plastic tray used to be:
4th: Install the 0dyssey PC680:
5th: Secure the battery with the top part of the tray using the 6mm Allen:
6th: Install the battery terminals with the 5mm Allen (put a small drop of loctite in the threads of the battery post cap screw) . Take note that the bigger one is the positive side (+/red) terminal. Then install the positive and negative cables and secure them with the 10mm wrench. ENJ0Y!
Old May 30, 2007 | 05:45 AM
PPI's Avatar
PPI
Nice write up!
Old May 30, 2007 | 09:08 AM
MyRoN's Avatar
Nice, but what is the benifit of a smaller battery..Weight?
Old May 30, 2007 | 10:08 AM
otter's Avatar
EvoM Administrator
Both losing weight in the front of the car and saving quite a bit of space in your engine bay.
Old Jun 7, 2007 | 06:52 PM
ambystom01's Avatar
Just finished installing mine. Overall it went well and was pretty simple, took about 20 minutes or so. Only two problems I ran into involved the positive terminal. First I had to remove my RRM heat shield because it was getting in the way and second the terminal just did not want to clamp down to the battery. After a few swears and some negotiation though I got the terminal to tighten down without popping off and all is good.
Old Jun 8, 2007 | 03:34 PM
boozeup&riot's Avatar
Regarding aftermarket car stereos and this mini battery kit, how nicely does this play with aftermarket stereos? I assume not so well. At the risk of sounding like a magnificent moron, I'll still just ask: I'm running the UDP and S & S with a second 350 watt amp to drive a pair of 12's in the trunk. I can only assume that this smaller battery may not drive all of that so well. Is that a poor assumption? Thanks as always for the patient answer.
Old Aug 6, 2007 | 10:10 PM
Realistic's Avatar
I second that.. Except..
I will have the udp.
and I have in total 1400 watts powering an aftermarket stereo
thanks
Old Aug 7, 2007 | 07:15 AM
otter's Avatar
EvoM Administrator
The battery's primary purpose is to start the car. Once the car is running, all electrical stuff, including stereo, are running off the alternator. I have the UDP and the minibattery, with a 1000w system, and I have no issues with power supply. The tradeoff, though, is if you like to sit there and listen to your stereo with the car turned off. The mini-battery has less reserve power than the stock one.
Old Aug 7, 2007 | 07:17 AM
PPI's Avatar
PPI
/\ excellant answer, thank you Otter!
Old Jan 16, 2008 | 11:05 PM
joshesh's Avatar
where can you get a set of those posts that use the allen to screw into the battery?
Old Jan 17, 2008 | 10:50 AM
robyn402's Avatar
does this braket have the ability to be bolted/mounted next to the fuse box?
Old Jan 17, 2008 | 11:21 AM
PPI's Avatar
PPI
You can't easily change where it mounts to the vehicle. This is because the mini battery tray uses the original battery supports.
Old Aug 26, 2008 | 08:11 PM
isaac085's Avatar
Where can i buy this Battery Kit
Old Aug 27, 2008 | 05:13 AM
PPI's Avatar
PPI
You can buy it through me. I sent you a pm!
Old Oct 23, 2010 | 06:01 PM
clyrusthevirus's Avatar
i need to get a mini battery! ^
nomoretransam
For Sale - Cars For Sale
Apr 19, 2017 09:11 PM
seven10
For Sale - Wheels / Tires
Apr 4, 2017 09:36 PM
jlldetroit
Aug 11, 2016 07:14 PM
pog0
Jan 23, 2016 05:31 PM
BriK
Sep 16, 2013 01:06 PM
