Help With RRM Black Tail lights!
So I just received my pair of black tail lights from RRM... However when installing I find that they do not fit very tight? Anyone else have this problem where the clips dont fit tight enough, which gives a gap between the lights and the body of the car?
I am thinking about replacing the mount pins on my black lights with the stock ones... Anyone else have any ideas? I am heading to work now and just wanted to post to see if I get any ideas by the time I get home
make sure you pull your little plastic pieces and rubber sleeves off your stockers that are on the posts and transfer them to your new ones, also, I used some double sided mounting tape on the back of them and gave them a firm push. So with the plastic and rubber condom looking thing on the posts and double sided tape, they are staying in there firm and look flush.
gbwaacha
Jan 13, 2006 04:40 PM
Sir Lancelot
Lancer Troubleshooting
Nov 14, 2004 11:27 AM
