Changing headlight bulbs, what a job.
Old May 19, 2007 | 05:30 PM
SlvrRalliart04's Avatar
I did it late this afternoon today. The drivers side was easy. The passenger side a total nightmare. I have little hands and had no room to get any leverage to pull plugs off the bulbs. My hands are all scratched up bad. Anyone who has done this knows. I think if the windshield washer bottle neck wasn't right there it would be so bad.
Putting them back in was a cinch. I replaced them Sylvania Silverstars. They look great, but should look better when I can really see them at night.
I can't wait to do the fogs.
Old May 19, 2007 | 05:57 PM
benny_ralliart's Avatar
i put sylvania silverstars in to and they are definitly brighter then stock, but i sure didnt have any problems putting them in, only took me like 5 mins.
Old May 19, 2007 | 06:19 PM
Realistic's Avatar
did you use the headlight bulb hatch opening?
sheesh
Old May 19, 2007 | 06:51 PM
otter's Avatar
EvoM Administrator
It takes a bit of work, especially for me with big hands. There's two tricks to that passenger side light. First off, disconnect the throttle controller. Second, you'd be surprised how much you can bend that washer fluid filler neck.
Whenever I change my lights, my hand is always bruised from pressing up against the throttle controller, even with the connector removed.
Old May 19, 2007 | 07:08 PM
bruce988jl's Avatar
did any of you guys break those tabs off the ring harness that hold the lightbulb in..?
Old May 19, 2007 | 10:05 PM
no cant say i did
Old May 19, 2007 | 10:07 PM
chengstar's Avatar
yup..all of them..LOL
anyways, trick to passenger side.
dont go straight down near the windshield fluid neck..
im not sure if i can explain this..but go near the engine..put ur arm between the wires and curve it towards the lightbulb area, there is alot of room to work with and will not scratch your hands. if needed, ill take some pictures..
heres a rough diagram.
Old May 19, 2007 | 10:28 PM
otter's Avatar
EvoM Administrator
That drawing looks pornographic.
And I've broken off most, if not all, of those stupid little tabs. By default, at least two must break off when removing the ring, and another 1-2 when reinstalling it.
Old May 20, 2007 | 12:43 AM
SR-V's Avatar
i love the detail pic of the engine.
the mivec lettering is priceless
Old May 20, 2007 | 07:54 AM
bruce988jl's Avatar
haha it looks like it says "VW Mivec" haha
But yea all those tabs are gone since i'ves swapped out numerous bulbs. Mainly because i use silverstars in the summer and some generic cheapo brand in the winters (the yellower tint works best for snow IMO)... I also run 3000K for the fogs, but have silverstars for them, but i never use them. haha
I window how hard it is to swap lights with aftermarket projectors...
Old May 20, 2007 | 02:54 PM
Thats how i ended up doing it, going underneath the cable there. But my arm was in such a weird position i felt i had no leverage to be able to pull it out, of course getting back in was easy.
I broke a little piece of plastic somewhere, very small piece, don't know what exactly it went to but everything is still holding in place fine.
Old May 21, 2007 | 05:28 AM
ddcha's Avatar
someone suspend him for posting a NWS picture!!! nice sketch dude.
Old May 21, 2007 | 05:30 AM
ddcha's Avatar
if you thought the headlights were hard, the fogs are about 10 times harder. First, you need to get underneath the car SAFELY. Next, once you remove all the plastic trim underneat to get to the foggies, you will probably strip the screw inside because it's made out of molded aluminum foil.
Old May 21, 2007 | 08:34 PM
chengstar's Avatar
i stripped the fog lights on...LOL
i'd draw another diagram.......but u guys know how i draw...
Old May 22, 2007 | 06:37 AM
bruce988jl's Avatar
I lost all my underpanels in an accident.. never bothered to replace it (not the best idea but o well). I just found some replacement screws for it at work and those seemed to work out well. Matched the thread and size pretty closely too.
Evo47
Apr 22, 2016 08:11 AM
EvilYeti
Oct 23, 2012 05:41 AM
jsdragonsoul333
Jan 3, 2011 01:48 AM
tim85851
Nov 28, 2009 02:46 AM
wiretap
Aug 7, 2005 05:19 PM
