HID problem
Old Nov 24, 2009 | 02:32 AM
tim85851's Avatar
Exclamation HID problem
so after my factory HID bulbs went out i replaced the factory D2S bulbs with some 6000k bulbs from xenonlink.com...just recently the driver side bulb would flicker like a strobe light then turn off...
it happens while im driving but if i turn the lights off and turn them back on it seems to reset them but it just happens again...the driver side bulb also seems to heat up almost instantly compared to the passenger bulb where it takes a few seconds or so...
is it just the bulbs? or should i be looking into something else?
Old Nov 24, 2009 | 02:37 AM
whoang40's Avatar
It's probably your ballast that's going bad. I'd swap the ballasts and see if the same problems follow to your other bulb.
Old Nov 24, 2009 | 04:06 AM
tim85851's Avatar
are there any fixes for this?
Old Nov 24, 2009 | 06:34 AM
garcias2k's Avatar
It sounds like a ballast is going out. Not sure if they are repairable, but I'd look around to try and find a used one.
I had that same issue with a flickering HID on my trunk. Turns out a ballast wasn't properly connected, but it had to be replaced anyways.
Old Nov 24, 2009 | 06:43 AM
JonahEVO's Avatar
Probably ballast because mine was flickering before before it went out.
Old Nov 25, 2009 | 12:19 AM
F0RSAKEN's Avatar
Is the ballast overheating at all?
Old Nov 25, 2009 | 12:37 AM
darkunitzero's Avatar
is this covered under warranty?
Old Nov 25, 2009 | 12:47 PM
EVO8emUp's Avatar
Is the car under warranty?
Old Nov 25, 2009 | 12:48 PM
evo_soul's Avatar
with a mod list like that. he should get a honorary warranty lol j/k
Old Nov 25, 2009 | 03:20 PM
sickaudi777's Avatar
i would think the bulbs try to get your money back and ask for new ones. Then go on from there
Old Nov 25, 2009 | 03:24 PM
bevolucion's Avatar
That's funny my driver side started doing that about a couple of weeks ago, I just haven't had time to take it all apart. But it seems that it happens when the bulb gets warm, flickers than goes off.
Old Nov 25, 2009 | 06:09 PM
Tangerine's Avatar
Swap bulbs from left to right and see if problem persists. If that is the case it most likely your ballast.
Old Nov 28, 2009 | 02:46 AM
tim85851's Avatar
good idea i didnt even think about trying that...ill do that and hope its just the bulb...
Evo47
Apr 22, 2016 08:11 AM
dcdirtrider
May 13, 2014 08:32 AM
warner
Aug 17, 2013 04:11 PM
Turvo
Aug 20, 2010 07:05 AM
wiretap
Aug 7, 2005 05:19 PM
