04-06 Ralliart Aftermarket Forced Induction Tech (aftermarket turbo/supercharger related topics)
intercooler question
Old Mar 14, 2007 | 08:43 AM
silversleeper's Avatar
Just a little FYI, there are companies that make water cooled intercoolers. Just incase your worried about cooling ect. I plan on getting one when I go turbo instead of a plain intercooler, helps to keep the temps down to a minimum and at a stead temp. Just thought I would throw that in there plus they look more like a radiator then an intercooler also. Might want to look into those also for that extra sleeper lool.
Old Mar 14, 2007 | 08:59 AM
fkdrcrs's Avatar
yeah my friend had a water to air cooling setup on his vr6. the only thing is that it was very expensive for him to get that setup done. i heard that its more efficient to have water to air cooled but im concerned with cost most of all.
Old Mar 14, 2007 | 09:36 AM
DangerousDan's Avatar
Originally Posted by fromWRXtoEVO
The performance is by no means affected.
I'm asking because I want to know, not because I am being argumentative. Is that the butt dyno or did you compare your intake air temps before and after?
Old Mar 14, 2007 | 10:18 AM
migueralliart's Avatar
you can get some calculations for the temps here assuming you know the pressure you want to run and the efficiency of the intercooler
http://www.rbracing-rsr.com/intercoolers.htm
Currently i am running an upgrade of the evo 8 intercooler (same as stock but thicker) for low boost daily driving. When I crank the boost up my water injection does the rest. Air/Air intercoolers are less efficient than Air/Water but in the end you don't have to go thru all the hassle of installing waterlines and an electric pump and a water cooler to the front of the vehicle in addition that the current draw from this kits is amazing. Water/Air intercoolers are most recommended for drag applications.
Last edited by migueralliart; Mar 14, 2007 at 10:22 AM. Reason: more info adquired
Old Mar 14, 2007 | 04:48 PM
lanzerralliart's Avatar
EvoM Super Moderator
my friend has an 12 second starion, and he just converted his windshield washer jets into the intercooler water cooler, he has them aimed perfectly and fills the container with water and ice , and water and dry ice , it does cool down his intercooler noticably....it's a cool idea I think.....
Old Mar 14, 2007 | 09:45 PM
fromWRXtoEVO's Avatar
Originally Posted by fkdrcrs
that is exactly the look i would want, thanks for the pics
i want it to where people cant see it unless they really look for it.
This intercooler is an used Evo 8 intercooler. It is a great performer and it is big enough for any turbo aplication. I picked mine for $125 or $150(used), that is a smoking deal and I think you should do the same.
Good luck!
Carlos
Old Mar 15, 2007 | 05:34 AM
fkdrcrs's Avatar
sounds like a good setup.
Old Mar 15, 2007 | 05:40 AM
I saw on diy tv a dodge neon (srt4) with a co2 spray kit for his intercooler. Talk about an advantage!
EmreEldelek
May 19, 2016 05:58 AM
clubEVO93
Feb 24, 2011 06:33 AM
Philisdiller
Jan 26, 2011 06:59 PM
Nuked
Jul 22, 2008 01:28 PM
ADizzle
Aug 18, 2005 11:54 PM
