04-06 Ralliart Aftermarket Forced Induction Tech (aftermarket turbo/supercharger related topics)
bogging problem
Old Jun 17, 2007 | 05:35 PM
Rallilanc's Avatar
bogging problem
I have the rrm turbo kit and the last few weeks i've had a serious bogging problem. When I really get on it the car bogs between 3500-4500rpm. The turbo is still spooled all the way, but the car almost pauses for a few seconds and then goes again. I don't think it is the clutch because the rpms aren't going crazy they just stay in the same spot. Can anyone help me out.
thanks
jack
Old Jun 17, 2007 | 05:50 PM
stEVOx's Avatar
fuel cut maybe?
Old Jun 17, 2007 | 06:35 PM
lanzerralliart's Avatar
EvoM Super Moderator
have you called rrm ?? that's probably your best bet as to find out whats wrong....
Old Jun 17, 2007 | 07:03 PM
Rallilanc's Avatar
haven't called yet was going to this week.
Old Jun 17, 2007 | 07:05 PM
otter's Avatar
EvoM Administrator
Do you have an a/f meter?
Old Jun 17, 2007 | 07:52 PM
Ralliart_on_LSD's Avatar
hmmm, never had this problem. fuel cut or MAJOR exhaust/boost leak? i dont think a boost leak will do that tho.
Old Jun 18, 2007 | 03:21 AM
Rallilanc's Avatar
yeah i have an auto meter a/f gauge, and it shows the car as running rich even when i'm bogging so i don't know if it would be a fuel cut.
Old Jul 1, 2007 | 03:51 PM
fallnone's Avatar
spark plugs maybe, try regapping them to a lower gap and going a step or 2 colder?
Old Jul 1, 2007 | 05:33 PM
otter's Avatar
EvoM Administrator
Don't regap your plugs if they're the stock ones, since they're iridium.
I've actually had the same thing start happening to my car. Mainly when cruising with the RPMs around 2000-3000rpm. I'm pretty sure it's my spark plugs, even though they're 15,000 miles short of the scheduled service interval. I have new plugs on the way and am running seafoam through my gas tank to make sure my injectors are clean. I also checked and cleaned my PCV to ensure that wasn't the issue.
Old Jul 1, 2007 | 07:24 PM
Thunder-rush's Avatar
Check for leaks in the turbo tract. If theres a boost leak your car wont spool that fast and the aditional fuel will cause bog. I recomend you to buy a quality A/F wide band gauge like Innovate or AEM if its too expensive buy at least a Greedy pirometer gauge. If you dont have even a boost gauge you really wont know whats happening and you car will suffer..! Jejeje..
Old Jul 4, 2007 | 10:20 AM
Rallilanc's Avatar
I checked the spark plugs and they looked alright, but i may buy some new ones just to see what happens.
As to boost leaks i don't believe i have one. The car is fully spooled during the bogging, and i do have a boost gauge and it reads between 6 and 7 pounds. I'm really not sure what it could be. I also had a problem a while back with my car going into a limp mode that is now starting up again, so I am completely confused with what's going on with my car. No one really seems to know why that is happening either.
Old Jul 4, 2007 | 01:10 PM
otter's Avatar
EvoM Administrator
Any CELs? If so, what codes?
Old Jul 5, 2007 | 04:05 PM
This is part of the tunning process there are so many variables that can lead to the problem. First you have to identify if the bogging is caused by a lean condition or too rich fuel mixture. The easiest and safest way to know is with a wide band gauge.
Old Jul 6, 2007 | 06:41 AM
DangerousDan's Avatar
at aftermarket turbo kit and no wideband
Old Jul 9, 2007 | 05:09 PM
Rallilanc's Avatar
hey otter the code that comes up is P2173, and Dangerous i believe that most of the people who bought RRM's kit did not buy a wideband.
