04-06 Ralliart Aftermarket Forced Induction Tech (aftermarket turbo/supercharger related topics)
Turbo Project!!!!
Old Aug 22, 2009 | 05:02 PM
  #226
Ralliart_on_LSD's Avatar
wow 347 hp and 311 tq is a healthy amount. have you taken it to the track recently? what are you running?
Old Aug 22, 2009 | 05:06 PM
  #227
Domolution's Avatar
Ahhhhhh!!!!!!!!!
What Monsta! :x
Old Aug 22, 2009 | 08:49 PM
  #228
qlitv's Avatar
No track times... haven't had the time to go...
Old Aug 23, 2009 | 06:32 AM
  #229
05lanceralliart's Avatar
Holy Sh*t thats freaking awesome. Mad props!
Old Aug 23, 2009 | 08:09 AM
  #230
manolo2011's Avatar
oye jorge voy pa turbo tambien y me gustaria saber donde hicistes el manifold y cuanto te salio...ademas de pal de dudas con el fuel y management system...porfa si puedes mandame tu cel por inbox o algo asi ya q no te veo por las flores...
Old Aug 23, 2009 | 08:10 AM
  #231
thats not fair... we cant understand that
Old Sep 12, 2009 | 02:36 PM
  #232
Thunder-rush's Avatar
I got those injectors too..! 720cc... I did this many years ago..wrx-sti top feed work great on our cars.
T-rush.!
Old Sep 12, 2009 | 04:46 PM
  #233
migueralliart's Avatar
Originally Posted by qlitv
Im using stock wrx injectos modified by agency power and yes they are top feed.
with the fic you can control the maf map on percent mode and it is easy to tune plus no limp mode
the only problem im encountering is some kind of boost cut, it may be some kind of sensor i have to get rid of or a vacuum line going some were from the manifold but i have to check on that, to lazy to do it now do any of you guys have an idea????
the car is running at 13.4psi 347whp and 311wtq..... but no good with that boost cut thing or what ever it is
OYe Jorge check the manual for the MAP voltage limit once it gets beyond a certain voltage the ECU just goes MAD
Old Sep 13, 2009 | 12:33 AM
  #234
qlitv's Avatar
thanks man ill check on that...
Old Sep 21, 2009 | 10:33 PM
  #235
JoeMivec's Avatar
Hey jorgito todo bien!!!!! I can't wait to take our ralliarts to the next level when we put our new toys right in jajajajaja cuidate loko.
Ralliart at 8psi 293.8
Old Sep 24, 2009 | 09:15 PM
  #236
SSP-Ralliart's Avatar
impressive power. Congrats.
Old Oct 2, 2009 | 04:30 PM
  #237
g469T's Avatar
nice project glitv,
ok, i have 04 ralliart 2.4 mivec and i am going for turbo
the question is:
1- the goal is only 6-7 psi with t3/t4 on full stock engine.. if i use a piggyback like megasquirt for controlling the Injectors only and leave the ignition and the other sensors for the stock ecu? is every thing will be ok? or the boost will make errors on the stock ecu and make problems with the drive-by-wire throttle, ignition, etc...?
2- the fuel rail must be replaced ? or i can use it for this amount of boost? and why i put the MAF after the turbo not before?shall i block-off the EGR system?
thanks alot for helping and sorry for the many questions, i want ur experience in this case because i am already bought the hardware turbo kit and going for this way even on extra injectors
Old Oct 3, 2009 | 07:36 PM
  #238
qlitv's Avatar
well first you can't just control the injectors with the a mega, if you use a megasquirt take advantage of it and make it stand alone other wise make a return fuel sistem with 450cc or 550cc injector and it will work perfectly with the psi you whant. Because by time, the stock ecu will regulate the AFR to what it is program to, example if the stock N/A AFR is 14.5 at WOT and you at turbo are doing 11.3 AFR then the stock ecu will change its own fuel value to make the AFR 14.5.
Or just get the rrm turbo piggy they say it works and it doesn't change the fuel values don't know about that cuz I had the N/A rrm piggy for fuel control once and by time it change my AFR.... But RRM say that it works with no problem
the fuel rail must be replace if you do a return system... you can use a evo aftermarke fuel rail its bolt on and at good price on ebay...
you have to put it after because if you dont use a resirculated system the engine will shut off cuz the maf reads the air coming in not the air coming out cuz of BOV. so if you put the MAF before then the MAF won't know the air coming out and it will still be throwing the same amount of gas, making the engine super rich and shut off.. So if you put it after the Maf will read the right amount of air and the engine won't die cuz of to rich.
you don't have to block the egr cuz at WOT it doesn't do anything
hope you understand and it help you....
Old Oct 3, 2009 | 11:05 PM
  #239
g469T's Avatar
yes u help me and i understand , thanx
but there is ONE point only i didn't get it in this car, or more specifically the ecu, i make research for this engine stock managment and i notice that everyone say that the ecu fight and make everything to adjust the afr to the 14.5:1 .
ok that's good words, but i want to say first the idea of the megasquirt as controlling the fuel, it doesn't hack the ecu injectors and re-tune the duration , i just remove the injectors wires from the stock ecu and connect the injectors directly to the mega to full control it, in other simple word, it's a stand-alone FUEL management with it's own's controlling fuel maps (if i leave the ignition to the stock)
Ok, after all that, how can the car ecu adjust the fuel -afr- although it doesn't touch the injectors? or it is very smart ecu that it can electronic regulate the fuel pressure in the fuel-rail to adjust the fuel?
ok, in case i trick the ecu by mega and force it to read 11:1 afr , will it be angry and throw many errors to the sensors? and shut the fly-by-wire throttle?and in case i use stand-alone for fuel, can i throw the maf without harming stock ignition timming?
agian thank u for helping
Old Oct 5, 2009 | 08:06 PM
  #240
g469T's Avatar
it's done
now the car running mega fine
thanx for helping
