04-06 Ralliart Aftermarket Forced Induction Tech (aftermarket turbo/supercharger related topics)
Turbo Project!!!!
Old Aug 15, 2010 | 08:06 AM
  #256
Matt_Jagg7's Avatar
Originally Posted by qlitv
well my turbo spools at 3500 to 4000 rpm its good enough for andthe car.. if you spool sooner you willhave a lot of tire burn...
its all about the driver...
Ahh ic ic. Well yeah your right all depends on the drivers preference. Either way Turbo RA's FTW!
Old Aug 29, 2010 | 10:46 PM
  #257
Xalos's Avatar
How did u mount the intercooler? I have the rrm turbo kit but the intercooler is too tall to fit
Old Aug 30, 2010 | 08:03 AM
  #258
lanzerralliart's Avatar
EvoM Super Moderator
You'll have to remove the crash bar or cut it....
Old Aug 30, 2010 | 08:13 AM
  #259
rj88's Avatar
if u remove the crash bar, wont u die in an accident?
Old Aug 30, 2010 | 08:58 AM
  #260
manolo2011's Avatar
don't remove it...just cut part of it...remember TURBO=$4K but YOUR LIFE= PRICELESS....just modify it...i will now change into a bigger intercooler too...and i will modify the bar...i will post some pics coming soon...
Old Sep 10, 2010 | 10:59 PM
  #261
chowetime's Avatar
I can't believe that i have missed this whole topic,,, and after an hours worth of reading of it and many more hours/days of reading throu other topics from this forum and others I have finally found what I need...
So you have just confirmed with me that the Eagle Evo 8 rods the same as the standard Evo8 rods and are a perfect fit in length nad the 87mm Wesco pistons are a perfect fit could I get you to confirm the part number for me the number that I have is K548M87
Loving the work you have done.
Well guys I have bad news and good news........
The bad news are that two weeks ago I made a soup of valve with a couple of pistons rings with a small touch of pistons.... because I installed the turbo smart manual boost controller but I didn’t add any boost.... but, it added 1.5 by itself just because it still adds a little psi even if is open all the way.... "I think"... correct me if I'm wrong please.... anyway I think the engine was hurt before it, cuz I was using nitrous, but things happens for a reason and that was to install some bad***s pistons and rods....
The good news are that I took this opportunity to buy a set of 87mm wiseco pistons and evo eagle rod...
Old Sep 10, 2010 | 11:08 PM
  #262
chowetime's Avatar
And just one other what compression are they now 8.5 ?
What did you do in the way of head gasket ? did you get one specially made up or just the standard Mitsubishi one?
I see you had a problem with your spark plugs as well I had Irridium in my original setup and when I went into WOT cylinder number one was touching. that plug was pretty much welded close - I am hoping that with my new build that I can not repeat this.
Old Sep 13, 2010 | 12:01 PM
  #263
rj88's Avatar
where is everyone getting their pistons from?
Old Sep 13, 2010 | 12:17 PM
  #264
ssg_petty_210's Avatar
i have some evo ix stuff for sale. If you see anything you might need, feel free to let me know.
Old Sep 13, 2010 | 12:52 PM
  #265
Mine are from weisco rj88 there was a link to it all here in the forum nut can't remember what thread...They make them upon ordering
Old Sep 13, 2010 | 01:24 PM
  #266
rj88's Avatar
^^^thanks, how much they run u?
Old Jun 8, 2011 | 05:44 AM
  #267
4g69 t's Avatar
Hey guys/girls i'm new to the forum. I have sourced the turbo kit from RPW. Currently running 9psi on stock internals making 171wkw/264hp give or take, but im looking to completely forge the internals within the next few months. Will be chasing around 400hp. Feel free to leave feedback
Attached Thumbnails Turbo Project!!!!-img_8058.jpg   Turbo Project!!!!-bay.jpg
Old Jun 8, 2011 | 06:10 AM
  #268
That looks and sounds promising, but I think you should start your own thread instead of just adding to this one, to get more interest. And add some more info and more pics IMO
Old Jun 8, 2011 | 01:53 PM
  #269
CrAnSwIcK's Avatar
400hp is quite ambitious for a front wheel drive, do you have an LSD, or plan on getting one? Also the clutch you'll need to hold on to that kind of power will be quite a clutch indeed, hope you don't have to drive in bumper to bumper traffic, lol
I'm very interested to see more, and what kinda of turbo do they use for their kits?
Old Jun 8, 2011 | 02:01 PM
  #270
Revo15's Avatar
Niceeeee! Lil Monster on the way
