04-06 Ralliart Aftermarket Forced Induction Tech (aftermarket turbo/supercharger related topics)
06 lancer running to rich
Old Jul 5, 2012 | 03:44 PM
06mitsuralliart's Avatar
I have a 2006 lancer with a road race motorsports turbo kit on it. I brought it to my gfs dads garage the other day because it was running really rough and the code came up as the front 02 sensor. I called tapp auto in Ottawa about it and they told me it was the sensor for the wb gauage so i ordered it and when i put it in the car is still running rough and running rich. I had also noticed my turbo manifold was cracked so i got them to fix that as well. Its still running the same and the air/fuel ratio at idle is 10 flat does anybody have any ideas to what it is. I was thinking a boost leak or something along that line
Old Jul 5, 2012 | 07:00 PM
lanzerralliart's Avatar
EvoM Super Moderator
What kind of turbo kit you have? Pics?
What fuel management system are you running?
Old Jul 6, 2012 | 05:40 PM
blaire's Avatar
if thats a rrm kit with a piggyback, then definitely reset your ecu. My fuel trims get ****kkked after like 1 month of driving the car. Runs like ****. Then if i reset the ecu and do the learning process car runs good.
Old Jul 8, 2012 | 01:35 PM
CrAnSwIcK's Avatar
hmmm, yeah definately reset the piggyback...and at least it's not lean, lol
Old Jul 26, 2012 | 01:45 PM
AdamRA's Avatar
It's not the piggyback sure the trims get whacked out but at idle the ECU should still keep it at 14.6-15.0 it should never cause the car to be exteremely out of norm.
I had this happen to my car was driving fine then all of a sudden 10.0 under any acceleration to the point it would die out (RRM's Filter has a metal disc that fell out cheap filter cheap on glue ). Anyway It's most likely a massive boost leak of some kind make a tester or search by eye if it's this big shouldn't be hard.
Too rich can damage the car after time so I hope you are not driving it like this.
Old Jul 26, 2012 | 03:58 PM
CrAnSwIcK's Avatar
an exhaust leak would normally give you lean readings, boost leaks as Adam stated could cause it to run rich...
pilchenstein
31
Jul 31, 2022 03:33 PM
89turbosupra
Oct 17, 2015 03:57 PM
tommyb123
May 29, 2015 10:36 AM
MarineEric
Feb 20, 2014 03:21 PM
silver9mr
15
Jun 12, 2013 09:46 AM
