04-06 Ralliart Aftermarket Forced Induction Tech (aftermarket turbo/supercharger related topics)
14b Low boost setup?
Old Mar 17, 2013 | 06:04 PM
Matt_Jagg7's Avatar
Originally Posted by Raikiri
Unfortunately at least for me the shop I was asking about building a kit for me, they were saying that doing a custom kit with running a standalone was going to run me near 10 grand -_-
WOW man its totally no where near that!!! Who quoted you that!!?? When i priced it up it was around 3-4k. But ill match RRM's price for party that i want a certain way.
lol yeah everything would've been done by the shop in terms of mock-ups, measurements, welding and brand new parts. they were saying the manifold would run like 1200ish and the downpipe would be like 500ish. but most of the cost would just be the manufacturing labor i think.
Motorsports Engineering (ME) makes the DP and Tubular manifold for any turbo flange for $800. Piece together your kit, dont but a kit from a shop or have them do the whole work. They charge that so they can make money on top!! Labor wise you can do most of that all yourself as well.
Regarding the Original Topic, Evo 3 16g, or t3/t4 set up like turbokits.com.
Maybe MTC Billet TD05?? http://shop.midwestturboconnection.c...illet-TD05.htm
Old Mar 19, 2013 | 08:36 PM
RacerX-Ralliart's Avatar
Motorsports engineering started makIng manifolds for us custom with wastegate/ without.. I should be getting mine in a couple of weeks..
Old Mar 19, 2013 | 08:43 PM
Raikiri's Avatar
Interesting. When I actually have funds this might be fun. That or sell off all my photo equipment for this lmao.
Old Mar 20, 2013 | 10:10 AM
mikemike396's Avatar
Sell! lol
Old Apr 12, 2013 | 12:39 PM
GRNMCH's Avatar
Originally Posted by CrAnSwIcK
On a 2.4L 4G69, the 7cm turbine housing and the bigger compressor on the 16 wheel should make a much bigger difference than it would on the 4G63, especially with larger diameter charge pipe, and the larger displacement engine, to fill that volume with enough air to create above atmospheric pressure it requires the turbo to move more air than it would on a DSM, this is where the 14b hot side becomes a restriction, and throws the pressure ratio off. a 16g will flow more air at the same RPM, thus creating equal boost at a lower RPM, allowing better flow (less "back pressure" i guess i'll call it) through the turbine section/wastegate.
I understand what you are saying, but in reality, the difference between 14b and 16g at such low air flow levels is very minor. 14b starts to run out of steam around 280-290hp, so anything under 250hp will give your nothing but 300-400rpm of turbo lag .
The real problem with 14b is finding a good specimen! But if you have it, keep it!
Old Apr 12, 2013 | 10:19 PM
CrAnSwIcK's Avatar
i have 3 14b's
SKY888
May 8, 2018 01:44 PM
Kevin_White19
Apr 12, 2017 01:47 PM
Tim Spillane
Mar 11, 2017 09:16 AM
03redtype-s
Nov 25, 2015 07:33 AM
toaster.evox
Oct 23, 2014 01:35 PM
