transmission problemo.
i was driving about 2 days ago..when i notice that when i go to nuetral when im stopping.. i hear a vibrating grinding noise..at fist i thought it was my rims..but i checked them and it was fine..i also have a problem shifting into first gear sometimes...it wont get into gear and il have to try 2 or 3 times to get it in gear.. i went to an oil changer and i got the transmission fluid checked and they said it was dirty.. so i had them put new fluid thinking it would fix the problem...but it didnt..so anyone know what the deal is?? everytime i stop i i hear a vibrating grinding noise and i have a hard time shifting to 1st gear sometimes..
how many miles? if its a shaky grinding, it could be the breakpads getting low. is it coming from the lower front center, or the sides? front breaks should wear out faster than side, but should still take ~15k miles to wear down
Have Mitsu check out your tranny.
Also, don't let those oil change places check your fluids, they'll *always* tell you that it's dirty and needs changing, and they're full of crap. You have an '05 RA, I guarantee that your fluid was just fine.
otterHave Mitsu check out your tranny.
Also, don't let those oil change places check your fluids, they'll *always* tell you that it's dirty and needs changing, and they're full of crap. You have an '05 RA, I guarantee that your fluid was just fine.Today 07:51 PM
the sound is coming from the front center..when i stop in nuetral it makes the sound...but when im in gear and i go to a stop it doesnt make the sound...but then its hard to shift it into 1st gear...i dont think its the break pads..it has to be the transmission..il have mitsu check it out tomorrow..it could be the bearing or the synchro..mitsu should cover it since i have the drivetrain warranty...i didnt modify any of the transmission parts yet..so they should fix it...thanks for replying guys..appreciate it.
hmm... so i'm not the only one with trans issues
https://www.evolutionm.net/forums/sh...d.php?t=108617
the transmission is fixed already..got the car back tuesday afternoon..they put a whole new transmission in there..they said the gears were messed up and they had to replace the whole thing..mitsubishi is pretty bad on transmission..but oh well...trading the car in soon for an EVO.
-joe
