04-06 Ralliart Engine/Drivetrain (no forced induction)
safc ii
Old Nov 10, 2005 | 11:48 PM
  #106
rhyzin's Avatar
ummmm, right. i don't know what you think takes 20 mins so i'm going to assume you have no idea what i was trying to do.
i guess that's what happens when you only read the last post of a thread.
Old Nov 11, 2005 | 12:25 AM
  #107
Jars1000's Avatar
Originally Posted by vboy425
that's why people disconect stuff before wiring it and double. it's pretty easy, no ore than 20 minutes job
How helpful...
Anyways, I'm sorry to hear rhyzin that the ECU is bein a *****. I for one definitely appreciate the lengths that you're going through to get this to work. Hopefully the ECU isn't fried...
Old Nov 11, 2005 | 09:17 AM
  #108
Myszkewicz's Avatar
Originally Posted by rhyzin
well i got the sensor the other day. i wired it in, and well.... i think i just fried my ecu. gonna spend my time trying to get the car started. otherwise, i'm gonna buy and wait for a new ecu.
bad bad ralliart mas!
i'm sure i wired it in right. i just think i may have crossed some terminals when i was checking with a voltmeter. oh well. you guys are on your own for now.
If it makes you feel any better, I let the smoke out of my front ECU a while ago, trying to get the fog lights to be independent of the headlights.
Get your ECU from car-part.com, rather than spend $1200 at a dealer.
Old Nov 11, 2005 | 08:48 PM
  #109
PR_Mivec's Avatar
damm i had hight hope on this one....
Old Nov 13, 2005 | 05:16 PM
  #110
DangerousDan's Avatar
me too
Old Nov 15, 2005 | 05:05 PM
  #111
rhyzin's Avatar
well i figured out what was wrong with my ecu and did a work around. i am a ****ing genius! i'm so happy i thought i'd share
anyhow, i'm going to build me a nice test circuit OUTSIDE of my car to test the airflow sensor this time
"replace ecu and go to step 12" MY ***!!!!
Old Nov 15, 2005 | 05:24 PM
  #112
Myszkewicz's Avatar
What was wrong, and what was your workaround?
Old Nov 15, 2005 | 05:58 PM
  #113
rhyzin's Avatar
i was getting these codes:
p0113 IAT voltage high
p0108 barometric sensor voltage high
AND the car wouldn't start.
usually the car should start even with those OBDII codes, but it wasn't. that usually means fuel pump, fuel pump relay, crank sensor, or cam sensor(there might be more but those are high on my list) are messed up as well.
so first i checked with the manual. i did my checks and when these sensors were backprobed, i got higher than normal voltage readings. the manual says to replace the ecu. well i'm poor right now so i thought i'd think it over first.
i pulled out the wiring diagrams and looked at what were hooked up to these sensors. I FOUND OUT the barometric pressure sensor, IAT sensor, crank sensor, and cam sensor ALL ground to pin 40 internally in the ECU. the ECU has 2 chassis grounds. that pretty much means if something grounds to the ecu, they'll pass through one of these two pins. i checked for resistance between pin 40 and these two ground pins. no dice.
so i took pin 40 out of the harness and hooked it up to a wire that i grounded to the chassis. BINGBANGBOOM the car starts. no codes, no problems, and seems to even gotten rid of a weird TPS bug i had.
so far a happy ending. gonna go give it a drive soon. i'll eventually replace the ecu, but not anytime soon.
Old Nov 15, 2005 | 09:03 PM
  #114
yeah, i would say you have earned your evom guru title. "BINGBANGBOOM"
Old Dec 21, 2005 | 03:50 AM
  #115
Starlite Demon's Avatar
well i just got mine on and up and running! its has good gains. pick up is better with all the gears at most of the RPMs (mostly about 3K and up). Tuned with a program called Digimotive.... i think thats what it was called....... well anyways its a great product to install if you have it!
Old Dec 21, 2005 | 06:12 AM
  #116
Myszkewicz's Avatar
So why don't you tell us how you got it to work?
Old Dec 21, 2005 | 08:56 AM
  #117
^^+5million
Old Dec 21, 2005 | 09:02 AM
  #118
Arithmetic's Avatar
Exclamation
Dude, thanks for the myspace comment, im now gonna get mine installed by him. Hey, did you know ricardo got one for his evo? We tried tunning it friday but the cold weather was just to much for us that night. Anyways, congrats ill be out there friday night to look at it.
Old Dec 21, 2005 | 09:44 AM
  #119
otter's Avatar
EvoM Administrator
Nobody is going to believe you unless you share how you got it to work, and people are able to replicate the success.
Old Dec 21, 2005 | 11:40 AM
  #120
well i went down to Boe's house in Hemet and he installed it since i have no clue about electrical -lol- It took about two hours to do. we did all the trial an error stuff. it scared me at frist cuz im trusting this guy that i met on the forums for the first time to tamper with my ECU. he first did it and the car just wouldnt turn over.... then he used some other sensor that made the car turn over for just like 2 sec then die.... then another where it started but it just sputtered like hell, then finally he started it up and it just ran.. it was awesome! U guys should talk to boe. i asked Rock about him installing the AFC but he also routed me to Boe. I can not tell any of you how to install and im sorry for that, but im just the driver and Boe is the person who deserves all the credit. I dunno if vids are good enough for u guys but im sure Arithmetic can get some vids of it up and running to show that i do have one installed and its actually working and maybe of pics of where to connect all this to the ecu? i dunno if that will help you.....
