04-06 Ralliart Engine/Drivetrain (no forced induction)
Question about gearing
Old Dec 6, 2005 | 04:58 PM
Myszkewicz's Avatar
Originally Posted by blackhawkRA
And I thought it has long-since been decided that the RA is drag-limited at 132mph or so?
It was. He and I are talking about our theoretical limit with the current gearing, rev limiter, and tire size. If your RA put down 600hp ( ), it still wouldn't go 150mph. It would get to 145 or so, and the rev limiter would kick in.
Old Dec 7, 2005 | 06:02 AM
Daddymac's Avatar
I agree about 4th being way too close to 5th... it's annoying for those of us who don't care for agressive freeway driving and want to drive aggressively on the streets and go for mileage on the highway. And I thought it has long-since been decided that the RA is drag-limited at 132mph or so? Or are you talking about after swapping out the final gear?
I was initially talking about swapping out 5th ONLY. But, it seems to be the popular decision that its not cost effective. SO, if i was to find a FD that has a slightly wider range then it might be worth while.
Old Apr 12, 2012 | 07:08 AM
samterry1234's Avatar
when it comes to the top speed, i dont think that it is drag limited at 132, i think it's electronically limited somewhere around 135. when i had my evo cluster in it would show just past 135 so i figure it to be about 134, and my gps speedo said 134 as well. plus i was reading somehwere on another forum abotu a reflash that "removes govern and raises rev limit"
Old Apr 12, 2012 | 07:25 AM
nekkidlad's Avatar
how about just a tranny swap?
i think i read somewhere a evo trans bolts up...(of course ud have to then figure outt he axles to make it FWD only or add in all the rest of the rear parts to make it AWD...)
how bout maybe a galant ot DSM or sumn else that still came w/ a 4g69?
theyre probably geared different as well...and im sure you could swap around from those...(of course that requires $, time and a guinea pig....)
Old Apr 12, 2012 | 08:24 AM
lanzerralliart's Avatar
EvoM Super Moderator
You do know this is a 7 year thread right, otherwise, we aren't electronically limited, we are drag limited. The other forum , club4g maybe? The eclipses come with a governor , apples and oranges.
Erik…
May 5, 2014 06:10 PM
Alpha X
Sep 9, 2011 07:01 PM
hakkoo
Mitsubishi TC-SST Discussion
14
May 21, 2011 10:23 PM
NavyEvoChief
Aug 7, 2009 08:31 PM
OhsixIXBish
26
Aug 25, 2008 04:45 PM
