04-06 Ralliart Engine/Drivetrain (no forced induction)
Crank Shafter Sensor
Old Apr 11, 2006 | 03:40 PM
MyRoN's Avatar
so i was driving in the rain and i drank up some water, with my injen cai, car stalled, and didnt start for a day, took it to the dealer they told me its a crank shaft sensor,
what do u guy s think......throw me ideas
Old Apr 11, 2006 | 06:08 PM
Myszkewicz's Avatar
If it was the crank position sensor that was keeping it from starting, then you didn't suck any water up with your CAI, You just splashed enough on the crank sensor to make it temporarily not work.
You should be more careful about driving through water with a CAI. If you *do* suck up water, you will severely damage your engine.
Old Apr 11, 2006 | 07:26 PM
MyRoN's Avatar
so it starts now, and i converted the cai to a short ram, to be on the safe side,
but the car still does not idel, it kind of sputters, but very litley,
it seems, like i lost alot of power, when i took out the spark plugs, for 35k miles, they were black as no other, i will take pics and post them, i replced them with pltnium 4 spark plugs,
but still nothing tooo exciting,
Old Apr 11, 2006 | 08:58 PM
MitsuJoe's Avatar
Sounds like a hydrolock issue. What is your next step?
Old Apr 11, 2006 | 09:02 PM
mirspeed1's Avatar
does it idle like that all the time or only when you first start it up?
Old Apr 11, 2006 | 10:33 PM
MyRoN's Avatar
it idles low then high, on a cold start, i actually never idled it after running it for a few hours, i will try that, but mitsu siad they "THINK" it is the crank shaft sensor.
I dont have a next step, got any ideas?
is it something i can replce myself, i might as well replace my timing belt while i'm at it..
help me..................
Old Apr 12, 2006 | 06:12 AM
mojambo's Avatar
the only I've heard of the crankshaft sensor going bad is on an RA in the canadian Rally series. It was in their first few events and the pounding of the rally killed the sensor. Its a quick fix from what I remember, cause the sensor is easily accesible on the side of the heads.
Old Apr 12, 2006 | 08:12 AM
MitsuJoe's Avatar
it sounds more like a vaccuum leak if it is surging at idle
Magrud3r
Nov 23, 2012 09:34 AM
donour
Dec 7, 2011 02:06 PM
acssa
Dec 6, 2011 03:38 PM
evo1008
15
May 23, 2011 02:14 PM
dcshoeco
Jun 19, 2009 11:33 PM
