Crank Sensor
Old Dec 6, 2011 | 08:53 AM
acssa's Avatar
Crank Sensor
Does anyone know how to test the crank sensor on evo8/9.
I know is a hall effect type...
Old Dec 6, 2011 | 09:11 AM
acssa's Avatar
on a audi 20v "A better test for the Hall Effect Sensor, is to make up a "low voltage" LED test light (LED with 120 ohm resistor in series) and connect the positive (+) side of the LED test light to terminal 1 (Red/Black wire) and the negative (-) side of the LED test light to terminal 2 (Green Wire) of the hall effect connector. This test is done with the connector plugged on to the distributor connector, and by pulling the rubber boot back off the connector to allow back probing the connector terminals.
The low voltage LED test light should flicker on/off when you crank the engine over during starting to indicate the hall effect sensor inside the distributor is working correctly.
Old Dec 6, 2011 | 09:30 AM
acssa's Avatar
the Evo sensor has a blue, red and black
Old Dec 6, 2011 | 10:26 AM
RSMike's Avatar
i hooked mine up to a power supply and an oscilloscope, then waved a piece of metal over it and made sure i got square wave output.
Old Dec 6, 2011 | 11:31 AM
acssa's Avatar
Am I correct in saying, Black wire= ground or - negative, Red wire: constant +12V
Blue wire= Signal wire that must give the 5V +-0.5V... square wave?
Old Dec 6, 2011 | 03:38 PM
RSMike's Avatar
yup sounds good.
not sure if it was 5V out or 12V out. Was a while ago now
Boosted_EvoVIII
59
Jul 1, 2014 10:56 PM
UKFive
Jun 6, 2012 07:19 AM
donour
Dec 7, 2011 02:06 PM
evo1008
15
May 23, 2011 02:14 PM
MitsuJoe
Jul 12, 2008 05:57 PM
