04-06 Ralliart Engine/Drivetrain (no forced induction)
Is Down Shifting Bad Or Good???
Old May 23, 2006 | 01:37 PM
MyRoN's Avatar
hey guys,
my lancer has 42k miles and my clucth is slipping
if i'm a high gear and hit the gas a little bit, my cluitch will drag and my tach will raise up fater than the engine, and then after a few seconds the engine catches up to the tach,
any body have this issue, seems to be getting worst,
now i do alot of down shifting, could this be the problem?
please help
unfortuantly, warrenty does not cover that
sooooooooooooooo
PLEASE HELP
Old May 23, 2006 | 03:57 PM
Khobin~'s Avatar
depends on "how you down shift...and at what rpm.
It could just be the result of hard lanching if you try to race a lot. Do you have the car modded a lot?
Maybe think about a performance clutch.
And yeah, clutches won't be covered.
Old May 23, 2006 | 04:01 PM
MyRoN's Avatar
only have a CAI, i down shift at about 4k rpms from 4th to 3rd then lower from 3rd to 2nd
i race alot tooo, so what would be a good clutch and how much would it cost, i called the stealer ship and they said 700
i saw one at rrm for about 500
Old May 23, 2006 | 04:48 PM
otter's Avatar
EvoM Administrator
Brakes are cheaper than clutches. You really shouldn't downshift to slow down, all it does is wear down your clutch and synchros. For the most part I only do it in autocross, and whenever I do, I always rev-match.
Old May 23, 2006 | 04:54 PM
2004Ralli//art's Avatar
haha...i like that...brakes are cheaper than clutches...
Old May 23, 2006 | 04:59 PM
Evodreamer28's Avatar
My advice to you to try and save whatever is left of your clutch is do not downshift at 4 thousand rpms. Wait for the rpms to drop a little lower so the engine and trans are not reving so high when you downshift. I normally down shift about 2500rpms or lower if I am coming to a stop or getting into slower traffic.
Old May 23, 2006 | 05:27 PM
Eclipse2Lancer's Avatar
My guess is too many hard launches and hard downshifts.
Otter is right....brakes are cheaper than clutches. I only downshift when needed in turns, emergencies, or on the track. And I heel toe like a SOB!
Old May 23, 2006 | 07:20 PM
MyRoN's Avatar
thanks for all the input,
i think my clutch is about done, even when i change from 1st to 2nd at about 2.5 or 3k rpms; and accelerate a little more, my tach still goes faster than the engine,
but when i'm driving around for hours, and it is really hot, everythign is fine..
so i'm a little confused
Old May 23, 2006 | 07:25 PM
You are explaining a typical slipping clutch. Time to start shopping for a new one before this one won't grab at all.
Old May 23, 2006 | 10:05 PM
DangerousDan's Avatar
you should learn to rev match, and heel and toe driving too. learning both of these techniques will help save your clutch and brakes as well. if you learn double clutch shifting you can even save the synchros from wear.
Old May 23, 2006 | 10:16 PM
Khobin~'s Avatar
brakes are cheaper then what??...
$700 for a clutch?...that's crazy.
I recently, like 3 weeks ago, got a new centerforce stage 1 for my xr, for the clutch, pressure plate, throw out bearing, pilot bearing and alignment tool it cost me $200, then due to some unfortunate cricumstances i ended up not being able to install it myself, so took it to a shop where it cost me $400 labour to get done, and they ground(not turned) the flywheel.
That's all in Cdn dollars for those you in the states, so if they are quoting $700 us that seems high, shop around, I had some places quote try to quote me $600+ for just the labour.
As for brakes, if I take it to a shop I'd expect to pay the same or more.
Downshifting isn't bad, doing it when you're already at 4000 rpm, just to slow down, was probably a contributing factor, I'd recommend the same as above, doing it around 2000-2500 when slowing down.
Old May 23, 2006 | 10:18 PM
wrecked's Avatar
I am alittle confused too. your tach goes faster then your engine? That isnt a slipping clutch, that is a faulty tach. A slipping clutch will cause the engine to rev up while not speeding up the car.
Old May 24, 2006 | 12:09 AM
NewRA's Avatar
whoa you guys all downshift in such high revs......I usually down shift below 2000 for top 3 gears, and even lower for 2
Old May 24, 2006 | 01:22 AM
SocalES's Avatar
i downshift all the time, but i always always rev match. when youre engine revs up as fast as out Mivec 2.4 does, it makes it a lot easier.
try rev matching in your car then try a civic, trust me its a whole world of difference lol.
only time i downshift hard without rev matching is to avoid an accident or if im going into way slower traffic. and even then i try to rev match if i can.
Old May 24, 2006 | 08:55 AM
MyRoN's Avatar
alright, this is what happens, when i hit the gas, the engines revs higher then it takes a few seconds to cath up with the clutch,
from what im hearing it is the clutch,
seems like i have to get it done sooner
so anybody has a how to step by step installation of our clutch, i will order the clutch from rrm and install it in a few weeks
let me know your input
