04-06 Ralliart Engine/Drivetrain (no forced induction)
RRM Cat Delete
Old Jun 7, 2006 | 04:20 PM
MikeyD's Avatar
RRM Cat Delete
Hey i was reading a guide on EvoM saying a good investment would be to buy a Cat delete ( im looking at the one from RRM) , n e one have this or think its personally a good investment. What effects does this have on yer car as far as sounds??
Old Jun 8, 2006 | 06:41 AM
Ralliart50's Avatar
Well, first of all you better crawl under your car to see if your cat is duel flanged. If it's not thne the RRM cat delete won't work unles you want to cut it and weld it in, but then you can't switch it back.
If you take out the cat your car is going to be a lot louder and raspy sounding. You will gain a few hp from it but I would personally recommend putting on a high-flow cat so that you are still legal, you keep some backpressure, and the sound doesn't get out of control. Just my .02.
Old Jun 8, 2006 | 07:29 AM
MikeyD's Avatar
aight but cat delete makes it much louder though =/
Old Jun 8, 2006 | 07:30 AM
MikeyD's Avatar
O & by the way in ohio its not illegal do have a high emision car so i dont have to worry about being legal unless it gets to loud.
Old Jun 8, 2006 | 08:42 AM
DangerousDan's Avatar
It will be a good deal louder. I did this and quickly bought the high flow cat. If you go high flow you will be losing less horsepower than you think. On the plus side you won't be unnecessarily polluting the environment. If you don't have a good muffler I suggest you get one if you delete the cat because it will sound like dookie under WOT at 2K to 2.5K and from 4K until you stop.
There is more restriction in that are of the car as well, specifically at the bend in the downpipe. You should really replace this and the cat with a DP and highflow setup to make more power. Even with the high flow cat you should still consider the muffler though. Thats where I am going next because it still doesn't sound mean, just loud.
Old Jun 8, 2006 | 08:43 AM
illegal or not, you should run with a cat. Please don't contribute to the detriment of our environment. Cat-delete is for track use where the 1/2 to 1hp gain you will get over a high flow cat is actually needed.
Old Jun 8, 2006 | 09:24 AM
MikeyD's Avatar
aight so im gonna go hi flo cat, its a weld on unit though, isnt it?
Old Jun 8, 2006 | 12:13 PM
Ralliart50's Avatar
Yep, it's a weld on. I would wait to get the RRM DP to weld it on though. Either that or you can just buy the new header with a high-flow cat.
Old Jun 8, 2006 | 12:27 PM
MikeyD's Avatar
Gracias, like u said, im gonna w8 on the new DP cause i dont want to have to take it off if u can even do that after its welded on.
JohnBradley
Sep 29, 2015 11:17 PM
Brian@RRM
87
Feb 12, 2010 09:34 AM
RarStlzLncr
For Sale - Cars For Sale
May 22, 2008 03:24 PM
say what
Nov 27, 2005 08:50 PM
