04-06 Ralliart Engine/Drivetrain (no forced induction)
Okay, so I've never reset the ECU
Old Aug 27, 2006 | 08:30 PM
Truffle Shuffle's Avatar
Bad?
I've put in a short ram intake, header, downpipe, magnaflow cat, cat back flowmaster exhaust and I'm about to put the pulley in.
Should I maybe after the pulley is in? Will I get any extra hp by doing so? What is the biggest benefit of resetting my ECU?
Thanks.
Old Aug 27, 2006 | 08:33 PM
PR_Mivec's Avatar
welll basically none......
some guy will tell you that it does something, but no.. it will only put the ecu on learning mode for the first 150 miles or so... and then bussiness as usual...
Old Aug 27, 2006 | 09:07 PM
DangerousDan's Avatar
150 miles? I have read and been told it is minimum 50 miles and good to go at 75 or so??? it takes as long as 150 juan?? I definitely trust your opinion over what I have read so far.
Old Aug 27, 2006 | 09:14 PM
Thanks, I was just making sure it's not harmful for the car if it doesn't reset or learn new parts.
Old Aug 27, 2006 | 09:54 PM
Myszkewicz's Avatar
The ECU is always learning, it just makes the largest adjustments very quickly after a reset, then fine-tunes itself from then on over the long term.
Old Aug 28, 2006 | 11:10 AM
PR_Mivec's Avatar
that was the exp from my car at least... example from cel light to cel light 150 even... before i had the 02 fix
Old Aug 28, 2006 | 10:58 PM
ahhh, thats a pretty good way to tell, I will adjust my numbers and use that as a reference in the future. Thanks for the clarification.
Hen5000
Mar 13, 2010 09:56 PM
marinejensen
10
Feb 9, 2009 01:22 PM
twisty1251
Apr 5, 2008 10:38 AM
voidhawk
Nov 10, 2007 06:04 PM
RanDEVO
Sep 4, 2004 11:18 PM
